pl2959 Posted December 10, 2008 Posted December 10, 2008 I installed AutoCAD 2009 64bit in a Vista 64bit computer. I got error message when I launch the application. The acad.exe application error message "Application failed to initalize properly (0xc0150002) click ok to terminate the application." Thank you. Quote
ReMark Posted December 10, 2008 Posted December 10, 2008 From what I have been able to gather it is not an AutoCAD problem but a Windows problem. Is Vista up-to-date with all service packs? Do you regularly create Restore points before making hardware chnages or before loading software to your computer? Quote
Ritch7 Posted December 10, 2008 Posted December 10, 2008 back terminator up 100% it has nothing to do with autocad initially, its a windows problem, but because ovbiously windows is ur OS it will therefore effect any programs u use. if you google the error code you will see exactly what im talking about im sure theirs soultions out there. Quote
pl2959 Posted December 10, 2008 Author Posted December 10, 2008 It is a brand new computer, i did not install any new hardware. Thanks Quote
