Flatten File using AutoCAD 2012 LT for Mac
Hello! First time post! I'm a long time user, but new to AutoCAD for Mac. I am trying to flatten a file. I could use a little help, thanks!
Well the flatten command might not be in the LT version. I thought it was only in the full version.
That is true, no FLATTEN command in LT. I have had horrifically disappointing results trying to select and then change all the object properties "Z" values to zero as well. The quickest way out would be to download the 30 day trial 2015 version of Full AutoCad for mac, flatten the drawing using the flatten command, then save it down to a version compatible with your release. (pre 2013 file format change).
You could try the CHANGE command and use the ELEVATION option. There is also a macro (or two) floating around that will work in LT. It has been posted here many times.
