Hi,
Is there a way to count a number of files in a folder using an autolisp coding.
Thx!
  • Replies 47
  • CadFrank
    23
  • Tharwat
    12
  • BlackBox
    5
  • hanhphuc
    4
I'm assuming there's a reason you want something other than just right clicking on the folder and selecting properties? :)
Just an example ;)
(if (setq f (vl-directory-files "C:\\Users\\Tharwat\\Desktop\\New Folder" nil 1))
 (length f)
(vl-load-com)
(defun c:FOO (/ *error* oShell oFolder path i)
 (defun *error* (msg)
   (if oShell
     (vlax-release-object oShell)
   (cond ((not msg))                                                   ; Normal exit
         ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
         ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
 (if
   (and
     (setq oShell (vla-getinterfaceobject
                    (vlax-get-acad-object)
                    "Shell.Application"
     (setq oFolder (vlax-invoke
                     oShell
                     'BrowseForFolder
                     (vla-get-hwnd acApp)
                     "Select folder to search:"
                     0
                     (+ 1 64 256)
     (setq path (vlax-get-property
                  (vlax-get-property oFolder 'Self)
                  'Path
      (prompt (strcat "\nSelected folder: \"" path "\" "))
      (prompt
        (strcat
          "\n"
          (itoa (setq i (length (vl-directory-files path "*.*" 1))))
          (if (= 1 i)
            " file "
            " files "
          "found."
 (*error* nil)
Well reason would be I'm trying to input a value in an attribut according to de number of drawing in the file.
Well thank Tharwat it almost what I need ill figure out the rest.
I changed
 (if (setq f (vl-directory-files (getvar 'dwgprefix) nil 1))
 (length f)
Thing is since the file is opened it count the .dwl and .dwl2
But like it said ill figure it out
Cheers & Beer !
I changed
 (length f)
Cheers & Beer !
You have to set the Extension parameter of the vl-Directory-Files function accordingly... "*.dwg" as example.
I changed
 (length f)
Cheers & Beer !
have a play with this then :)
(if
 (and (setq
            (getvar 'dwgprefix)
            nil
            1
      (setq l (vl-remove-if '(lambda (ex) (wcmatch ex "*.dwl,*.dwl2")) f))
  (length l)
(if
 (and (setq
            (getvar 'dwgprefix)
            nil
            1
  (length l)
Is the OP attempting to quantify everything except *.dwl* files, or all files of one or more specific extensions?
I am trying to get the .dwg files.
But I wanted to figured out the rest.
:D
Thx !
I guess all files as it is clear from the title of the thread :)
I can certainly appreciate that, however....
... ^^ This ^^ should have been included here, in order to avoid this:
Cheers
:D
Thx !
So give your self a favor by reading about the function vl-directory-files
Well I was going to !
I ain't an guru yet :P
Thx for the help !
Thx for the help !
Not a problem , just ask if you stuck with anything :)
Well I just read on the Vl-derectory-files. Now I feel bad it actually says what I wanted lol !
Shoulda dug more hehe would've found the answer in my book :)
 (length f)
FWIW, the if statement is not required since (length nil) = 0
(length (vl-directory-files (getvar 'dwgprefix) "*.dwg" 1))
I am always concern about the first statement before feeding or processing to conclusion and good to know that length function would exit safely if argument is equal to nil . :)
Thanks a lot .
Ok! well i've been on this for a few more hours and can't figure it out!
Now If I want to make sure that in the file it counts files with a specific string only.
For exemple :
(setq
            (getvar 'dwgprefix)
            "*.dwg"
            1
("1456546756.dwg" "2014-08-11 - LU-14094 - Plan de coffrage des culées - rev.00.dwg" "2014-08-11 - LU-14094-02 - Plan de coffrage des culées - rev.00.dwg")
Now using :
(setq l (vl-remove-if '(lambda (ex) (wcmatch ex "*LU-14094*")) f))
("1456546756.dwg")
Now I've tried alot and can't seem to figure out how to extract the other one.
Any one can Help plz!
maybe?
(setq l (vl-remove-if[color="red"]-not[/color] '(lambda (ex) (wcmatch ex "*LU-14094*")) f))
