maybe?
(setq l (vl-remove-if[color="red"]-not[/color] '(lambda (ex) (wcmatch ex "*LU-14094*")) f))
Omg!! that function existed...
Seriously I must of been blind.
Thanks alot
  • Replies 47
  • CadFrank
    23
  • Tharwat
    12
  • BlackBox
    5
  • hanhphuc
    4
you are welcome. we help each other :)
Sure when I can help I will.
Cheers !
You should be able to use:
(vl-directory-files (getvar 'dwgprefix) "*LU-14094*.dwg" 1)
Well I'm back with another question !!!
(vlax-for lt (vla-get-layouts adoc)
   ;(vla-put-activelayout adoc lt) ; optionnel
   (vlax-for obj (vla-get-block lt)
     (if (and (= "AcDbBlockReference" (vla-get-objectname obj))
             (member (vla-get-effectivename obj) Nombloc)
             (= :vlax-true (vla-get-hasattributes obj) ))
         (setq atts (vlax-invoke obj 'getattributes))
         (foreach x atts
    (if (= TagRev (vla-get-tagstring x)) ;<---- the if is what changes all the time.
               (vla-put-textstring x TRev)
So I've been using this code alot in my code. Is there a way to make it shorter so I don't repeat it all the time.
Like a smaller program that I call
Make it a sub-function; create a new DEFUN and call that sub-function supplying the Document parameter within your code instead of duplicating same.
Cheers
Well thats what I don't understand !
don't know how to make my sub functions to work!
Don't understand the arguments in the brackets !
So thats where i need help :(
Thanks
Edited by CadFrank
Thanks
If it's possible i'd only like to be pointed in the right direction :D
With respect to what BlackBox suggested and I hope that he would not mind if I translated his idea to reality for you Frank , so here it goes .
(defun change-attribute-textstring (adoc TagRev Nomblo)
              (= :vlax-true (vla-get-hasattributes obj))
       (foreach x (vlax-invoke obj 'getattributes)
Usage of the above function :
(change-attribute-textstring (vla-get-activedocument (vlax-get-acad-object)) <text_string> <list_Block_names> )
Well I tried what you wrote down but I think you might of been missing another part of the code.
When I test your code it end up doing nil at the end but does not modify the text of the attribut.
So here's what I do
(defun _Modification (/ obj atts x lt Nombloc)
(setq Nombloc '("LU CARTOUCHE"		  "Cartouche Aliance"
	"LC CARTOUCHE CHUM"	  "LC CARTOUCHE CHUM 2"
	"LC CARTOUCHE"		  "LU CARTOUCHE PANNEAU"
	"CARTOUCHE LU"		  "LC CARTOUCHE 2"
(initget 1 "P T D V")
(setq Mod (getkword "\n Quel élément voulez vous modifier? [Projet/Titre/Date/Verificateur] : "))
 (if (= Mod "P")
 (setq TProjet (strcase (getstring T "\n Quel est le nouveau nom du projet? ")))
 (setq TagPro "PROJET")
 (change-attribute-textstring (vla-get-activedocument (vlax-get-acad-object)) TProjet Nombloc)
Now the sub-function
(defun change-attribute-textstring (adoc Tag Nombloc)
         (if (= Tag (vla-get-tagstring x))
           (vla-put-textstring x Text)
So here it is !!
Upload a sample drawing of what you are working on to allow me to test it out for you .
Test.dwg
There we go !
The attributes I want to change are all in the Layouts and I want to change all at the same time.
The names of the two blocks in each layout is not included in the list of block names in your codes , so the function could not find them to make any change .
Technicaly the only block I want to change some attributes is "CARTOUCHE LU"
but in the future I might have more different names but with the same attributs.
We are talking about current time , and I asked you to upload a sample drawing and you uploaded a drawing with different story . Up to you .
The tag string is case sensitive so when you lower the string from the routine you should also lower the tag string in the sub-function that I wrote before .
Ok give me a second the the current drawing I though I changed all the tag string !
Somehow I can't upload more file :S
Ok go it! Test2.dwg
Might help you more if i posted the full code also !
;¦¦¦ CE PROGRAM EST CONÇU POUR REMPLIR LES CARTOUCHES                        ¦¦¦;
;¦¦¦ _______________________________________________________________________ ¦¦¦;
;¦¦¦ AUTEUR : François Lévesque CadFrank, Copyright ® 2014                   ¦¦¦;
;¦¦¦ Ce sous-program construit une liste à partir du chemin du dessin actuel ¦¦¦;
(defun _FilePath->List (filePath / i folder folders)
 (setq filePath (vl-string-translate "\\" "/" filePath))
 (while (setq i (vl-string-search "/" filePath))
    (setq folders (cons (setq folder (substr filePath 1 i)) folders))
    (setq filePath (substr filePath (+ 2 i)))
 (reverse folders)
);fin _FilePath->List
;¦¦¦ Ce sous-program done la date                                            ¦¦¦;
(defun _Today ( / d yr mo day)
    (setq d (rtos (getvar "CDATE") 2 6)
         yr (substr d 1 4)
         mo (substr d 5 2)
        day (substr d 7 2)
    );setq
    (strcat day "-" mo "-" yr)
);fin TODAY
;¦¦¦ Sous-program pour un début de projet                                    ¦¦¦;
(defun _NouvProjet (/ lt obj atts x id lay_field
	    TagPag Tag#Pg Tnumtabs TagPro TProjet TagTit TTitre TagNPr TNProjet TagNPl
            TNPlan TagDes TagVer Tnumtabs TProjet TTitre TNProjet TNPlan Tdes Tver)
;| Élénment de text |;
 (setq Tnumtabs (itoa (length (layoutlist)))
TProjet (strcase (getstring T "\n Quel est le nom du projet: "))
       TTitre (strcase (getstring T "\n Inscrire le titre : "))
TNProjet (substr (nth 5 (_FilePath->LIST (getvar 'dwgprefix))) 1 8 )
l (length (vl-remove-if-not
	   '(lambda (ex) (wcmatch ex (strcat "*" TNProjet "*")))
	    (vl-directory-files (getvar 'dwgprefix) ".dwg" 1)
TNPlan (strcat TNProjet "-0" (itoa l))
 (initget 1 "C F J S")
 (setq	Tdes (getkword "\n Qui a dessiné le plan [Charle/François/Julieta/Simon]: "))
       (if (= Tdes "C")(setq Tdes "CHARLES LATENDRESSE, Tech"))
(if (= Tdes "F")(Setq Tdes "FRANÇOIS LÉVESQUE, Tech"))
(if (= Tdes "J")(setq Tdes "JULIETA LJUBICH, Ing"))
(if (= Tdes "S")(setq Tdes "SIMON DROLET, Ing"))
 (initget 1 "J S")
 (setq	Tver (getkword "\n Qui est l'ingénieur du projet [Julieta/Simon]: "))
       (if (= Tver "J")(setq Tver "JULIETA LJUBICH, Ing"))
       (if (= Tver "S")(setq Tver "SIMON DROLET, Ing"))
;| Élénment des TAG |;
 (setq TagPag "PAGE"               ; étiquette de l'attribut numéro de page
       Tag#Pg "#PAGE"              ; étiquette de l'attribut nombre de pages
       TagPro "PROJET"             ; étiquette de l'attribut Projet
       TagTit "TITRE"              ; étiquette de l'attribut Titre
TagNPr "N°PROJET"           ; étiquette de l'attribut Numero de N° Projet
       TagNpl "N°PLAN"             ; étiquette de l'attribut Numero de N° PLAN
TagDes "DESSINE"            ; étiquette de l'attribut Nom du dessinateur
TagVer "VERIFIE"            ; étiquette de l'attribut Nom du vérificateur
         (foreach x atts
     (if (= TagPag (vla-get-tagstring x))
               (setq id (vla-get-objectid (vla-get-layout (vla-objectidtoobject adoc (vla-get-ownerid obj)))))
               (setq lay_field (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id)">%).Taborder \\f \"%tc1\">%"))
               (vla-put-textstring x lay_field)
    (if (= Tag#Pg (vla-get-tagstring x))
               (vla-put-textstring x Tnumtabs)
           (if (= TagPro (vla-get-tagstring x))
               (vla-put-textstring x TProjet)
    (if (= TagTit (vla-get-tagstring x))
               (vla-put-textstring x TTitre)
    (if (= TagNPr (vla-get-tagstring x))
               (vla-put-textstring x TNProjet)
    (if (= TagNPl (vla-get-tagstring x))
               (vla-put-textstring x TNPlan)
    (if (= TagDes (vla-get-tagstring x))
               (vla-put-textstring x TDes)
    (if (= TagVer (vla-get-tagstring x))
               (vla-put-textstring x Tver)
 (_Revision)
 (vla-put-activelayout adoc (vla-item (vla-get-layouts adoc) 1)) ; activer Layout1, optionnel
);fin NouvProjet
;¦¦¦ Sous-program pour une révision du plan.                                 ¦¦¦;
(defun _Revision (/ TRev TDesc Tdate TPar TApp
	  TagRev TagNRev TagDesc TagDat TagPar TagApp
	  lt obj atts x DynBP)
 (if (= choix "N")
     (setq TRev "0"))
 (if (= choix "R")
   (setq TRev (itoa (fix (getreal "\n Numéro de révision : ")))))
 (setq TDesc (strcase (getstring T "\n Donner la raison de la révision. : "))
       Tdate (_Today)
 (setq	TPar (getkword "\n Qui a fait les changements sur le plan? [Charle/François/Julieta/Simon]: "))
       (if (= TPar "C")(setq TPar "C.L"))
(if (= TPar "F")(Setq TPar "F.L"))
(if (= TPar "J")(setq TPar "J.L"))
(if (= TPar "S")(setq TPar "S.D"))
 (initget 1 "J S")
 (setq	TApp (getkword "\n Qui a approuvé les changement [Julieta/Simon]: "))
       (if (= TApp "J")(setq TApp "J.L"))
       (if (= TApp "S")(setq TApp "S.D"))
 (setq TagRev "REV"
       TagNRev (strcat "N°REV" TRev)
       TagDesc (strcat "DESCRITION" TRev)
       TagDat (strcat "DATE" TRev)
       TagPar (strcat "PAR" TRev)
       TagApp (strcat "APP" TRev)
;Inscrit le texte dans chacun des attributs
         (foreach x atts
    (if (= TagNRev (vla-get-tagstring x))
    (if (= TagDesc (vla-get-tagstring x))
               (vla-put-textstring x TDesc)
    (if (= TagDat (vla-get-tagstring x))
               (vla-put-textstring x Tdate)
    (if (= TagPar (vla-get-tagstring x))
               (vla-put-textstring x TPar)
    (if (= TagApp (vla-get-tagstring x))
               (vla-put-textstring x TApp)
    (setq DynBP (nth 2 (vlax-invoke obj 'GetDynamicBlockProperties)))
           (vla-put-value DynBP TRev)
); fin _Revision
;¦¦¦ Sous-program pour une modification des information du projet.           ¦¦¦;
(defun _Modification (/ obj atts x lt)
 (if (= Mod "P")
;¦¦¦                           Début du Programme                            ¦¦¦;
(vl-load-com)
(defun C:PG (/ choix adoc Nombloc)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq Nombloc '("LU CARTOUCHE" "Cartouche Aliance" "LC CARTOUCHE CHUM" "LC CARTOUCHE CHUM 2" "LC CARTOUCHE" "LU CARTOUCHE PANNEAU" "CARTOUCHE LU" "LC CARTOUCHE 2"))  ; nom du bloc cartouche
  (initget 1 "M N R")
  (setq choix (getkword "\n Quelle étape voulez-vous entamer? [Modification/Nouveau/Révision] : "))
  (if (= choix "M")
      (_Modification)
  (if (= choix "N")
      (_NouvProjet)
  (if (= choix "R")
      (_Revision)
);fin defun c:
But it's not completed and I'm no expert here! So the code might now be well designed !
And i'm in a French country :S
And BlackBox Doesn't know it but he help alot in it :)
Did you mean attributs here?
Or else I'm not really following what your trying to tell me..
Sry
