helpme Posted August 13, 2014 Posted August 13, 2014 Hi all i have some projects designed in digital projects and saved as ifc file when i export to revit all the files become as mass and i couldnt edit them. Please help Quote
tzframpton Posted August 13, 2014 Posted August 13, 2014 IFC doesn't translate 100%. Revit 2015 made an astronomical stride in IFC support and is the best I've seen yet when exchanging IFC through import/export. Unless I can obtain the IFC files to test myself, it's hard to help or offer any further advice. IFC is tricky and a case by case basis, but one thing's for certain: it's never as seamless as you wished it was. They will stay generic models/mass elements. You will have to re-model from scratch if you want to do it right, unfortunately. Quote
helpme Posted August 13, 2014 Author Posted August 13, 2014 i have some ifc file, when i import them in revit 2014 i can see them only on 3d view and it is in mass when i click on edit mass option and when i select it looks like a grouped file and when i try to explode it it gives an error saying 3d objects are not seen so only 2d something like that.... feel sad that i cant edit them or cant see the properties of the file: cry: Thank you so much for the answer..... Quote
Rahim Shaikh Posted December 3, 2014 Posted December 3, 2014 send me your IFC file so i can test .... Quote
