creating assemblies please help me....?
hi all
i need Assemblies according to cross section please anyone help me iam getting problem in curb and median and cut fill slope please suggest me best tutorial pdf or video also
thank you
Personally I would create it starting from the CL using a Sidewalk Assembly. Place it at -2% then curb etc etc. Once done select
all the assemblys, right click and select mirror.
thank you jerryG,
i know basic assemblies and done corridor also earth work quantity reports also done
i need creating own sub assemblies according to cross section how to start
There is nothing there that is custom. All the assemblys you need are there.
Start with the left side using a sidewalk assembly - give it the width/depth you need.
then attach the curb assembly to the end of the sidewalk by selecting the little circle
on the top left edge. Then insert the road assembly etc etc. make sure you are specifying that it is a "Left" attachment .
For the landscape buffer use a sidewalk and give it a depth of .01
how to create sub assemblies...?
i tried polyline to assemblies that option is select poly line ok color also change now...
* how to add code (right click add code but what i write there)
* kerbstone (i need same like .dwg)
* cut fill daylight option (need 1:4 only extend to ngl)
when i create polyline to sub assemblies then add basic daylight or any other sub assemblies not accepted problem is the object is not sub assemblies.
please suggest me,
thank you.
