When I paste special my excel file with border table into the drawing under auto cad entities option, the table is corrupt and collapsed, while the text is correct outside of the table. I'm using windows 7 64 bit and land desktop 2004. I used this process for years and am now having this problem. Any help is appreciated
Are AutoCAD tables available in 2004? That would be a much better option than paste special.
I don't believe there was a Table command in 2004. I think it was added in 2005.
From JTB World re: AutoCAD 2005....
"TABLE is a new command that lets gives you almost the same table functionality that is in Microsoft Word. You can copy data from Excel and use Paste Special using AutoCAD Entities option. This will create a table in AutoCAD. Blocks and Fields can also be included in a Table."
