Wall not showing up when selecting a start point on line drawing?
Hi I'm using autocad architecture 2012.
My problem is when I select a start point to draw my wall on a standard line drawing it doesn't show up. This hasn't been a problem before. I always create a line drawing to outline my floor plan then create the wall style and then add it in.
I have loaded up other files and its working fine I also copied and paste my drawing into another file and it still isn't working. You can draw the wall anywhere else, you can also draw a line and select a start point from that and it works but not if I select a start point on a line in the drawing I have done. I don't see how those lines are any different.
Any suggestions?
Try using the wall designs in tool paletes to convert the lines into walls
