abishop Posted August 15, 2014 Posted August 15, 2014 Inventor 14............ I am trying to dimension a Diameter to the CL of a hole pattern...... HOW? I am trying to dimension the angle these. How? I have attached .pdf Thanks Andy B CL Circle.pdf Quote
abishop Posted August 15, 2014 Author Posted August 15, 2014 got it. never mind.................patience Quote
gbradley Posted August 15, 2014 Posted August 15, 2014 How did you do it? Did you Sketch two lines and then dimension the Angle? Quote
abishop Posted August 18, 2014 Author Posted August 18, 2014 Click Annotate tab and then use teh Centered Pattern. Good Luck! Quote
