wing
Braces over multiple lines
wing
Currently using Autocad 2012 vanilla. Would like to add round brackets/parentheses around multiple lines "mtext". It is very common to show line annotations this way in Australia. Right now I use two mtext with different text height. The parentheses' text height is obviously larger to suit the number of lines.
I've tried OLE microsoft equation via "insert objects" in autocad but it:
  • does not like my "Autocad only valid font"
  • cannot be rotated.
I can probably program this in AutoLISP but it will take me some time. Is there an existing solution?
PS: Yes, I am aware of the typo, i.e. missing a minute ' symbol.
Share this post
Link to post
BIGAL
Two different suggestions two lines of text the bottom line is mtext eg (12.34) with the brackets oversized and top line text or mtext a lisp would do it, the other way if possible is to subscript the first ( bracket and over size not sure if you can do this. A 3rd method is to wrap the text with two brackets again it would be seperate text. ( )
Share this post
Link to post
rvpas
Hi,
You can use a dynamic block with multiline attribute
TX-BRACE.dwg
Share this post
Link to post
ReMark
What is the reasoning for enclosing bearings/angles and distances in brackets? Why two lines of text and not one?
Share this post
Link to post
BIGAL
Remark found one it so you dont add the distance of the easement to the length of the side
Share this post
Link to post
wing
Long story short, this drafting convention is inherited down from the age where such drawings were hand-drawn by surveyors. Please don't ask me why technology is ahead of law/conventions.
Share this post
Link to post
wing
Hi,
Thanks rypas, this seems useful. Sorry I missed your post earlier.
Share this post
Link to post
