lisp to replace a single character in a text string
Hello,
I haven't done Lisp programming in about ten years and need a quick fix. Would someone please help me get started with this requirement:?
lisp to select a single character in a text string and replace it with another character.
I know how to select the string and get it into the selection set SS.
Thank you in advance!
Welcome to CADTutor!
Since you're dealing with a selection set within your active document, have you considered simply using the FIND Command?
Cheers
I would like to use the lisp routine in a batch file.
I have found this routine fantastic for both simple and complex 'find and replace' functions. I tried to get one to do specifics myself, and stumbled on this that did what I wanted and much more. You may not need to re-invent the wheel ;)
As usual... from the guru Lee Mac:
http://www.lee-mac.com/bfind.html
That would have been useful information in the OP, as in a batch process using ObjectDBX, selection sets are not supported as they are in Scripts (because the drawings are not opened in the editor).
1+ for BFIND.
Hello,
hi jmseiver, ithink below lisp will Solve your troubles, i write and test it in my computer, it works
;;;;<make sure your CAD express tools can be used>
;;;;design by shaodeng000 <take a hour>
(defun c:tt ()
 (acet-error-init
   (list (list	"cmdecho" 0
;;;               "highlight" "
	"osmode" 0 "limcheck" 0	"pickstyle" 0) ;list
  T
   )					;list
 (setq	flt '((-4 . "<OR")
      (0 . "TEXT")
      (0 . "MTEXT")
      (-4 . "OR>")
 );select strings
 (setq gop1 (ssget flt))
 (setq gop gop1)
 (if (not #str_x2)
     (setq #str_x2 "stringold")
 (setq	str_x2 (getstring (acet-str-format
		    "\nenter ori string<%1>"
		    #str_x2
 (if (or (not str_x2)
  (equal str_x2 "")
     )	;or
   (setq str_x2 #str_x2)
   (setq #str_x2 str_x2)
 );set a original string that you want to replace.
 (if (not str_x1)
     (setq str_x1 "stringnew")
 );set a new string.
 (setq	str_x (getstring
	(acet-str-format "\n<%1>instead of<%2>"  str_x1 str_x2
	  );end acet-str-format
 (if (or (not str_x)
  (equal str_x "")
     )					;or
   (setq str_x str_x1)
   (setq str_x1 str_x)
 (change_str gop1 str_x1 str_x2)
 (acet-error-restore)
(defun change_str (gop str_new str_old / ent entname i)
 (setq i 0)
 (repeat (sslength gop)
   (setq entname (ssname gop i))
   (setq ent (entget entname))
   (setq strings (cdr (assoc 1 ent)))
   (setq str_change (vl-string-subst str_new str_old strings))
   (entmod (subst (cons 1 str_change) (assoc 1 ent) ent))
   (setq i (1+ i))
Hello,
command:FIND
or try function
;http://www.cadtutor.net/forum/showthread.php?88249-lisp-to-replace-a-single-character-in-a-text-string
(replace$ ss new old)
;argument:
;ss   = selection set
;new = new string, 'STR
;old = old string to be replaced, 'STR
(defun replace$	(ss new old / str) ;hanhphuc 2014
 (if ss
   (mapcar ''((x)
       (while
	(and (setq str (assoc 1 (entget x))) (wcmatch (cdr str) (strcat "*" old "*")))
	(vla-put-textstring (vlax-ename->vla-object x) (vl-string-subst new old (cdr str)))
    (vl-remove-if ''((e) (listp e)) (mapcar 'cadr (ssnamex ss)))
    ) ;_ end of mapcar
   ) ;_ end of if
 ) ;_ end of defun
Test:
;note: case sensitive
(replace$ (ssget "X") "NEW" "OLD")
please test which character can't be replaced?
example: "#"
@ hanhphuc
Why do not you build the appropriate filtration codes per requirements to avoid any failure of codes ?
eg and as per your last posted codes here .
... '((0 . "*TEXT")(1 . "OLD"))
@ hanhphuc
Thank you sir for advise, appreciated.
yes, i know the above ssget is normal good practice as shown in post#6
i just wanna try something difference or variant
which i filter in a list (ssnamex) (assoc 1 ..) (wcmatch ..), but i still don't know known bugs
that's why argument i use ss to be tested by user
i believe you know more bugs far more than me because your experience is not a short cut, in a glance you can easily spot it. Debugging is a good lesson agree? :)
p/s: known bug: " " (blank) may be trapped in while loop
Edited by hanhphuc
Note that this could become simply:
(vl-remove-if 'listp ... )
Though, there is no need to iterate over the selection set data returned by ssnamex more than once, e.g.:
(defun replace$ ( sel new old / obj )
   (if sel
       (foreach itm (ssnamex sel)
           (and (= 'ename (type (cadr itm)))
                (setq obj (vlax-ename->vla-object (cadr itm)))
                (vla-put-textstring obj (LM:stringsubst new old (vla-get-textstring obj)))
;; String Subst  -  Lee Mac
;; Substitutes a string for all occurrences of another string within a string.
(defun LM:stringsubst ( new old str / pos )
   (if (setq pos (vl-string-search (strcase old) (strcase str)))
       (strcat (substr str 1 pos) new (LM:stringsubst new old (substr str (+ 1 pos (strlen old)))))
       str
yeah 3rd eyes always "sharper", thank you for spending your time to correct it, i noted for today's lesson :)
i also learned vl-string-search method from you similar to Lee's which i didn't notice, nice!
