Airfoil conversion program
I work with airfoils quite a bit. Those having an overall length of One unit, and the endpoint begins at 0,0.
I was given a couple airfoil conversion programs, but they limit the coordinated counts to just a few numbers, and do not recognise curves of lines making up the airfoil. They recognise only endpoints. One annoying theng was that once disolved one program wrote out a tabulated list of end coordinates, but then destroyed the work next time the computer was turned on.
Any airfoil programs out there that I can try and see if it works as anticipated? I need the LISP program to follow a line, cite the two coordinates to endpoints, and the write those to some standard two column TXT file. Simple I would think.
Wm.
