naghshe Posted August 23, 2014 Share Posted August 23, 2014 How can I change the angle type to "Surveyors unit" for all projects. I have to do this change for every single file I open. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 24, 2014 Share Posted August 24, 2014 These sit in the back of the Units command you can set these as part of a autoload so it runs for each dwg as its opened, make sure your default dwt is set up correct. (SETVAR "LUNITS" 2) (SETVAR "ANGBASE" 0.0) (SETVAR "ANGDIR" 0) (SETVAR "LUPREC" 0) (SETVAR "AUNITS" 0) (SETVAR "AUPREC" 0) Quote Link to comment Share on other sites More sharing options...
naghshe Posted August 24, 2014 Author Share Posted August 24, 2014 These sit in the back of the Units command you can set these as part of a autoload so it runs for each dwg as its opened, make sure your default dwt is set up correct. (SETVAR "LUNITS" 2) (SETVAR "ANGBASE" 0.0) (SETVAR "ANGDIR" 0) (SETVAR "LUPREC" 0) (SETVAR "AUNITS" 0) (SETVAR "AUPREC" 0) What is autoload and how can I set it? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 25, 2014 Share Posted August 25, 2014 I refer to the ability to automatically load a lisp every time you open a dwg, do a search here or google for acaddoc.lsp there are some clear explanations on how to use. Quote Link to comment Share on other sites More sharing options...
naghshe Posted August 27, 2014 Author Share Posted August 27, 2014 I refer to the ability to automatically load a lisp every time you open a dwg, do a search here or google for acaddoc.lsp there are some clear explanations on how to use. Thank you. Would you please explain the variables on the code, so that I set them up they way I want to. I just used them the way you wrote it, but it needs to be changed. Quote Link to comment Share on other sites More sharing options...
