Registration-Activation Error (0015.111)
How can i remove this Error Registration-Activation Error (0015.111) in AUTOCAD 2014
Please help me
You might want to do a general Internet search on the error code you are seeing. Or visit the AutoDesk website and search there.
Are you trying to load this program on a second (possibly a laptop) computer?
Where did you obtain your copy of AutoCAD 2014 from?
You should NEVER post an activation code in a public form. I'd take that down immediately.
In the market? What market?
You have posted personal Serial Number on an open forum, not a good idea.
What is "Market"? url please!
What is X-FORCE?
I think Xforce is a key generator in which case the OP may have purchased his copy of AutoCAD outside the normal channels.
Key generators are programs used to generate keys for pirated software.
mfa: CADTutor does not condone the use of illegal (pirated) software.
The problem with some key generators is that in the process of downloading them users also unknowingly download viruses and/or malware. You get more than you bargained for and not in a good way.
Actually - the Activation Code is is irrelevant as it would only work for one particular machine. It is the Serial Number (if it had been valid) that can be used by anyone.
If you're using xforce to generate an activation code then you have a pirated copy of the program. So, if you did in fact contact Autodesk for assistance, you may have just jumped from the frying pan into the fire. Good luck with that. ;)
