Get previously selected objects
Hi,
I know how to get the client to select objects, for example with SSGET.
But how do I read the objects that are already selected, the moment the client types the command of my program?
Example: I have 300 cameras, pointed in any direction.
I want to turn some of those cameras 90° clockwise.
- With QSELECT I first select the cameras with an angle between -45° and +45° (or those with color=blue; ...)
- Then I type my new command.
- Those cameras all get a rotation 90° less than they had.
Never mind, it looks like (ssget "I") does the trick.
I guess it should be P which stands for previous selected object(s) and L stands for last object created . if memory serves .
Yeah, it's the "I" I need. Just the pickfirst selection.
Here are all the options if you are interested .
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle/SUbobject/Object
Hi, Tharwat. I think he's talking about using the ssget function, where most of the available options are covered below (from AutoLISP Reference Guide 2013):
C Crossing selection.
CP Cpolygon selection (all objects crossing and inside of the specified polygon).
F Fence selection.
I Implied selection (objects selected while PICKFIRST is in effect).
L Last visible object added to the database.
P Last selection set created.
W Window selection.
WP WPolygon (all objects within the specified polygon).
X Entire database. If you specify the X selection method and do not provide a filter-list, ssget selects all entities in the database, including entities on layers that are off, frozen, and out of the visible screen.
:E Everything within the cursor's object selection pickbox.
:N Call ssnamex for additional information on container blocks and transformation matrices for any entities selected during the ssget operation.
:R Allows entities in a long transaction to be selected.
:S Allow single selection only.
:U Enables subentity selection. Cannot be combined with the duplicate (": D") or nested (":N") selection modes.
I left a space in the colon D option to avoid a smiley.
I guess you are right . thank you neophoible .
