Creating Materials volume reports from Corridor
Hi all,
I have a corridor set up, with custom subassemblies using shape codes to calculate materials like pavement, concrete, base and subbase. I cut quantity sample lines along all of the base lines and used a materials list to produce dynamic volume tables in the drawing for both cut/fill (earthworks) and all of the materials mentioned above. All of this works great.
What I need is to create a PDF report for all of the materials. The Volume Report tool works for the cut/fill quantities, but when I try to produce a materials report, all of the cells just reflect a quantity of 0.00.
With the Volume Report tool, there doesn't seem to be a way to specify the material within the material list so I'm guessing that that tool is meant for cut/fill volumes only. Anyone know how to produce material volume reports short of using the plot command to plot each of the tables in the drawing to PDF?
