KaiBo Posted December 10, 2008 Posted December 10, 2008 I am trying to write a function that checks if an Excel workbook is open (read only or not), and if it’s open assign a variable to it. I have found many examples of how to test if an Excel workbook is open from excel VBA, but can’t get it to work in AutoCad VBA. Any help in getting this code to work in Autocad would be appreciated. This is the Testing function I have so far: Function WorkbookOpen(WorkBookName As String) As Boolean ' returns TRUE if the workbook is open WorkbookOpen = False Dim Wbk As Workbook 'On Error GoTo WorkBookNotOpen If Len(Excel.Application.Workbooks(WorkBookName).Name) > 0 Then MsgBox "WorkbookOpen = True", , "Testing MsgBox" WorkbookOpen = True Exit Function End If MsgBox "WorkbookOpen = False", , "Testing MsgBox" WorkBookNotOpen: End Function Thanks, Kai Quote
borgunit Posted December 10, 2008 Posted December 10, 2008 This returns an error which you can capture... Public Function GetOpenExcelWorksheet() As Excel.Worksheet '------------------------------------------------------------------------------ ' 'Arguments: None 'Returns: Excel worksheet ' 'Example: 'Dim xlObj As Excel.Application '''''''''''''''''''''''''''''''''''''''' 'Set xlObj = GetOpenExcelWorksheet '------------------------------------------------------------------------------ On Error GoTo ErrHandler Dim sPath As String Dim xlApp As Excel.Application ''''''''''''''''''''''''''''''''''''''' Set xlApp = GetObject(, "Excel.Application") 'Set gWorkbook = gExcelApp.Workbooks.Open(sPath, , True) Set GetOpenExcelWorksheet = xlApp.ActiveSheet If (GetOpenExcelWorksheet Is Nothing) Then Err.Raise vbObjectError + 513 ErrHandler: Select Case Err.Number Case 429 MsgBox "Excel Is Not Open" Case -2147220991 MsgBox "Excel Has No Active Worksheet" Case Else End Select Err.Clear End Function Quote
KaiBo Posted December 11, 2008 Author Posted December 11, 2008 Thanks Borgunit’s, Perhaps I was not clear, I am trying to determine if a specific workbook is open. Not whether any workbooks are open. The point of all this is I am trying to avoid opening several versions of the same workbook. In trying to alter Borgunit’s code to check if a specific workbook is open, I get error 9 as long there is any workbooks open. Quote
