Your dwg is not about TEXT HEIGHT it looks like you want a chainage and level routine ie take length of line at a scale and add datum to get level and set horizontal distance as well. Must it be VBA I have something close in lisp. Pretty simple to do. Method is to create selection set of lines using the fence option rest is just length of line and X distance from a start pt.
i need to select only the text portion or the full drawing by lisp or vba and can i get the result as per my requirements? because the scale in which i have to produce the drawing i am unable to show the text to readable.
The text height is a property of text or mtext you need to do some home work on object properties via VBA, Layer color lineweight linetype rotation style to name a few. This is pretty basic stuff. Start searching "VBA Textstring"
ThisDrawing.Utility.GetEntity PitNameSlect, basepnt, "pick text : "
If PitNameSelect.ObjectName = "AcDbText" Then
dia1 = val(PitNameSelect.TextString)
