copy and paste
Guest NUBBZ143
Normally when working between AutoCAD and Inventor I can just copy and paste from one to the other respectively. Recently, though, the paste part isn't working in Inventor from AutoCAD. As far as I know, no options have been changed on my computer. I was wondering if anyone has had this problem or if anyone has a fix for it.
Works fine for me, I often do it, try the insert autocad dwg button to see if that works?
Perhaps a check on the paste destination to verify whether or not layer mgr is set-up correctly. If inadvertlingy layermgr either freezes and/or turning off default layer(s), paste thus would not show in Inventor.
Something so simple can go awry.
