Wojciech Posted August 30, 2014 Posted August 30, 2014 Hi. It is possible to install dll in AutoCAD LT 2014? If so, what command? Quote
Dana W Posted August 30, 2014 Posted August 30, 2014 .dll, a dynamic link library? If one is missing, you may find it on your install disk via the Repair option in Windows Control panel. Quote
Wojciech Posted September 2, 2014 Author Posted September 2, 2014 I mean, instal plugin. For eg. ADNPlugin-ClipboardManager.dll. But I read somethere, that it is impossible in AutoCAD LT. Quote
rkmcswain Posted September 2, 2014 Posted September 2, 2014 As far as I know it is not possible. Does the NETLOAD command work in LT? Quote
Dana W Posted September 2, 2014 Posted September 2, 2014 As far as I know it is not possible.Does the NETLOAD command work in LT? If that is for loading dot net code, then no. Quote
