issammesk Posted September 3, 2014 Posted September 3, 2014 hi all can you help me i have ablock table cotain text as attribute value and when make layout it show me this table without attribute vale just table Quote
ReMark Posted September 3, 2014 Posted September 3, 2014 Attach a copy of a drawing to your next post that contains the block. Someone here will take a look at it. Quote
RobDraw Posted September 3, 2014 Posted September 3, 2014 There are a few ways this could happen. Most common is probably a layer frozen in the viewport. My guess would be that it is an annotative scale issue. Quote
SLW210 Posted September 3, 2014 Posted September 3, 2014 Did you try ATTSYNC? ATTSYNC See Also Modify a Block Attribute Definition Updates block references with new and changed attributes from a specified block definition. Access Methods Button Ribbon: Home tabBlock panelSynchronize Attributes Toolbar: Modify II Command entry: attsync Summary You are prompted for the names of blocks you want to update with the current attributes defined for the blocks. Use this command to update all instances of a block containing attributes that was redefined using the BLOCK or BEDIT commands. ATTSYNC does not change any values assigned to attributes in existing blocks. Note: Use the ATTREDEF command to redefine and update blocks in one command. Entering ? displays a list of all block definitions in the drawing. Enter the name of the block you want to update. Pressing ENTER allows you to use your pointing device to select the block whose attributes you want to update. If a block you specify does not contain attributes or does not exist, an error message is displayed, and you are prompted to specify another block. Warning ATTSYNC removes any format or property changes made with the ATTEDIT or EATTEDIT commands. It also deletes any extended data associated with the block, and might affect dynamic blocks and blocks created by third-party applications. Attach the drawing if possible. Quote
