ali222 Posted September 3, 2014 Posted September 3, 2014 I want to draw cross section of road using data in excel like chainage distance elevations etc. Quote
BIGAL Posted September 4, 2014 Posted September 4, 2014 7o7 this has been asked for so many times, a cross section consists of chainage offset & level so excel would be The only hard bit is the cross section spacing, row line spacing spacing and getting it all to work at scale. I would go the easy way first and just work from a CSV file. Then look at the individual components, draw vertical lines, draw surface line, draw horizontal lines. A extra bit to this is to draw a alignment and then read all the values and create line work you add a 4th excel column which is description. Last comment pretty sure this may exist in some of the free civil software out there. Quote
SLW210 Posted September 4, 2014 Posted September 4, 2014 Try CadTools, it should do what you need. Quote
