davidoff Posted September 4, 2014 Posted September 4, 2014 Please if a Guru here will give me the procedure to measure the length of an arc in Solidworks. Bear in mind that I am as new to the software as you can get, so please be as rudimentary as possible. I am using Solidworks 2010 if it matters at all. I enclose a simple example in the jpg format. Thanks in advance, Ahmad Davidoff Quote
JD Mather Posted September 4, 2014 Posted September 4, 2014 Click Evaluate>Measure and select the arc. Quote
SuperCAD Posted September 6, 2014 Posted September 6, 2014 Do you want to measure it or place a dimension for the arc length? For a dimension, start the dimension tool then click on both ends and the arc itself. Remember, there are three clicks that are needed to create an arc length dimension: end point one, end point two and the arc itself. Quote
