liuhaixin88 Posted September 4, 2014 Posted September 4, 2014 Hi all, I want use three command to save view and use three command to restore view. eg. command "save_view1" to save view, view name is "view1" command "restore_view1" to restore view to "view1" ......view2 ......view3 Quote
BlackBox Posted September 4, 2014 Posted September 4, 2014 These should get you started.... Save view: (defun c:ViewSave () (command "._-view" "_s") (princ)) Restore view: (defun c:ViewRestore () (command "._-view" "_r") (princ)) Quote
liuhaixin88 Posted September 4, 2014 Author Posted September 4, 2014 These should get you started.... Thank you! BB I know. (defun c:ViewSave1 () (command "._-view" "_s" "view1") (princ)) (defun c:ViewRestore1 () (command "._-view" "_r" "view1") (princ)) Quote
liuhaixin88 Posted September 4, 2014 Author Posted September 4, 2014 (defun c:ViewRestore () (vl-cmdf "._-view" "_r" "view1") (princ)) "command" and "vl-cmdf " Which is better? Quote
BlackBox Posted September 4, 2014 Posted September 4, 2014 Thank you! BB I know. You're welcome, liuhaixin88; I'm happy to help. Cheers Quote
BlackBox Posted September 4, 2014 Posted September 4, 2014 "command" and "vl-cmdf " Which is better? They're functionally the same, but COMMAND always returns Nil, whereas VL-CMDF returns T which may be useful in test expressions, etc. Cheers Quote
liuhaixin88 Posted September 4, 2014 Author Posted September 4, 2014 They're functionally the same, but COMMAND always returns Nil, whereas VL-CMDF returns T which may be useful in test expressions, etc. Cheers Hi BB, Good teaching . Thank you again. Cheers Quote
BlackBox Posted September 4, 2014 Posted September 4, 2014 Hi BB, Good teaching . Thank you again. That is kind of you to say, liuhaixin88. Quote
David Bethel Posted September 4, 2014 Posted September 4, 2014 I use something similar to this : [color=#8b4513];;;SAVE[/color] [b][color=BLACK]([/color][/b]defun c:sv [b][color=FUCHSIA]([/color][/b]/ p v vn vi[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq p [color=#2f4f4f]"VIEW"[/color] v 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq vn [b][color=NAVY]([/color][/b]strcat p [b][color=MAROON]([/color][/b]itoa v[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]tblsearch [color=#2f4f4f]"VIEW"[/color] vn[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq v [b][color=MAROON]([/color][/b]1+ v[b][color=MAROON])[/color][/b] vn [b][color=MAROON]([/color][/b]strcat p [b][color=GREEN]([/color][/b]itoa v[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 6[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq vi [b][color=NAVY]([/color][/b]getint [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"\nView Number To Save <"[/color] [b][color=GREEN]([/color][/b]itoa v[b][color=GREEN])[/color][/b] [color=#2f4f4f]">: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]or vi [b][color=NAVY]([/color][/b]setq vi v[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.VIEW"[/color] [color=#2f4f4f]"_Save"[/color] [b][color=NAVY]([/color][/b]strcat p [b][color=MAROON]([/color][/b]itoa vi[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;RESTORE[/color] [b][color=BLACK]([/color][/b]defun c:rv [b][color=FUCHSIA]([/color][/b]/ p vl td ev vi[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq p [color=#2f4f4f]"VIEW"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]setq td [b][color=MAROON]([/color][/b]tblnext [color=#2f4f4f]"VIEW"[/color] [b][color=GREEN]([/color][/b]not td[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ev [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 2 td[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]= p [b][color=GREEN]([/color][/b]substr ev 1 [b][color=BLUE]([/color][/b]strlen p[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq vl [b][color=GREEN]([/color][/b]cons [b][color=BLUE]([/color][/b]atoi [b][color=RED]([/color][/b]substr ev [b][color=PURPLE]([/color][/b]1+ [b][color=TEAL]([/color][/b]strlen p[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] vl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]terpri[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1 [b][color=NAVY]([/color][/b]reverse vl[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]or [b][color=MAROON]([/color][/b]not vi[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]member vi vl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]initget 7[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq vi [b][color=MAROON]([/color][/b]getint [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\tView To Restore: "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.VIEW"[/color] [color=#2f4f4f]"_Restore"[/color] [b][color=NAVY]([/color][/b]strcat p [b][color=MAROON]([/color][/b]itoa vi[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] I use a different prefix from "VIEW", but the same scenario. -David Quote
liuhaixin88 Posted September 5, 2014 Author Posted September 5, 2014 That is kind of you to say, liuhaixin88. haha. Quote
liuhaixin88 Posted September 5, 2014 Author Posted September 5, 2014 I use something similar to this : I use a different prefix from "VIEW", but the same scenario. -David David , A good routine. Thanks for sharing. Quote
