Faouweb Posted September 5, 2014 Posted September 5, 2014 Hi, I have created a new CTB with all colors number 9 except 4 and 14. But when I do a preview the colors does not change! I am using AutoCAD 2013. What I have to do? Thank you Quote
ReMark Posted September 5, 2014 Posted September 5, 2014 Did you test your new plot style by actually plotting a drawing? If so, what was the result? Quote
RobDraw Posted September 5, 2014 Posted September 5, 2014 Post a screen shot of your plot dialog box. Quote
Faouweb Posted September 5, 2014 Author Posted September 5, 2014 Here are some screen shot, and the ctb: test.zip Quote
RobDraw Posted September 5, 2014 Posted September 5, 2014 It looks like everything is good with your plot settings. Maybe it's the visual style. I haven't done much printing of 3D AutoCAD so I can't guide you on that. Quote
Faouweb Posted September 5, 2014 Author Posted September 5, 2014 OK Thank you RobDraw ------------------------------------ I forgot to say that I use Realistic Visual Style. Quote
rkent Posted September 5, 2014 Posted September 5, 2014 Visual Styles will override the ctb/stb settings. If you want it to show as all gray then change the visual style to monochrome. If you need some pipes to show in color while all the others are gray then you will have to do that at the layer color level rather than the ctb. Quote
Faouweb Posted September 5, 2014 Author Posted September 5, 2014 Visual Styles will override the ctb/stb settings. If you want it to show as all gray then change the visual style to monochrome. If you need some pipes to show in color while all the others are gray then you will have to do that at the layer color level rather than the ctb. Yes it works only with 2D wireframe , I have changed the color in VP Color. Thank you for your help Quote
