minivdub Posted December 11, 2008 Posted December 11, 2008 hi there my current job involves adding window and door schedules which i can do easily enough, when i place them into the drawing assuming i am in MEDIUM detail they will show up, if however i change to LOW detial the schedules dissapear. can anybody explain why and possibly how to correct this? thanks Quote
Noahma Posted December 11, 2008 Posted December 11, 2008 I will be able to look into it in a bit, I usually don't use display reps for the work I do, but I think I know how to solve your prob. Quote
Noahma Posted December 11, 2008 Posted December 11, 2008 go to your display manager, click on the low detail in the right hand side of the screen, then go to plan low detail, in the right part of the screen check to see if schedule table is checked. in this area of ACA, you can choose what is displayed, or not. the display rep. bar at the top shows what part of the display you want it shown in (if that makes sense) So if you want your curtain wall to show in model, but not in plan you would check your model box, and not your plan box. Quote
