willsmith Posted September 9, 2014 Posted September 9, 2014 I m using Autocad 2011. When i am using mirror command in a particular file,The file becomes not responding.Then i need to close the autocad file. Please Suggest Solution Quote
Tyke Posted September 9, 2014 Posted September 9, 2014 First audit and purge the drawing using the "-purge" (note the minus sign before the word purge and don't type the quotation marks) command from the command line, using the "All" option. Then try writing the entire contents of the file to a new drawing using the WBLOCK command. Quote
