extract text height from a picked single line text
any idea how to get text height when i picked single line text
Hi.
Try this .
(if (setq s (ssget "_+.:S" '((0 . "TEXT,MTEXT"))))
 (setq hgt (cdr (assoc 40 (entget (ssname s 0)))))
hello tharwat thanks for reply
can we extract text height from this selection method
(setq 1pt(entget (car (entsel "\nSelect text: "))))
Sure , but you have to be sure that the user selected a text and not any other object ;)
Anyway here it goes .
(setq hgt (cdr (assoc 40 1pt)))
thank you tharwat for your kindness
You are welcome anytime :) .
Have a read of THIS which consist of all related DXF codes for the single line text
VL example same thing no test for if text
(setq obj (vlax-ename->vla-object(car (entsel "\nSelect text: "))))
(vla-get-textstring obj) ; text entered
(vla-get-height obj) ; height of text
(vla-get-rotation obj) ; text angle
; to mention a few if you want more download Dumpit.lsp this will produce list
; or
(entget (car (entsel))) ; this will show dxf code numbers like 40 above
Edited by BIGAL
