Filribeiro Posted September 11, 2014 Posted September 11, 2014 Hi, What is my goal: to select multiple dimensions entities and obtain the sum os all of them. In the image below i should be albe to select the 2 dimensions and the result of the command/routines should respond me "5". Someone know a routine/command for that? Thanks in advance! Quote
ReMark Posted September 11, 2014 Posted September 11, 2014 Try over at The Swamp. SMadsen has a routine called TXTSUM.lsp that calculates text vlaues and dimensions. Quote
