how to sum rounded values in field table
I've been using the lisp AreaLabelV1-9 by lee Mac (saved huge effort for me, 10x by the way) for makig table with areas of a floor plan.
In my pre- editted acad table (room number/ room name/ area (sqm)) I've been inserted the areas with "insert cell"option of acad.
All good till now!
The problem is that I have to calculate the sum of area values at bottom of the table and the "sum" function uses for calculations whole value of areas( all digits after comma) and the result is correct but different than summing the shown values.
ex:
1. 1.34 sqm (displayed) 1.33561120 sqm (real value)
2. 2.23 sqm 2.22559221 sqm (real value)
3. 4.45 sqm 4.45562100 sqm (real value)
Total 8.01 sqm (displayed) .....8.02 sqm (from summing the displayed values)
The logical solution would be to round all table values at 2 decimals roud(c1,2) etc..and then to make the sum. But till now I didn't figure out how to do it.
I have to make around 900 tables (for each floor plan) and for each appartment brom the building.
Can anyone please help me with a lisp/suggestion/ whatever in order to obtain the sum of rounded values in field table???
You can change the following lines in Lee's code (each appears twice in code):
(strcat "[color=red]%<\\AcExpr (0.01*round([/color]%<\\AcObjProp Object(%<\\_ObjId "
                         (_GetObjectID acdoc p1) ">%).Area[color=red]>%*100))[/color] \\f \"" fo "\">%"
and
(strcat ap (rtos (* cf (vla-get-area p1)) 2 [color=red]2[/color]) as)
However, this will affect only new tables.
Also you must consider others settings, like DIMZIN or FD variable in Lee's code.
Many Thanks Stefan!
It worked and it gets me out of trouble.
Many Thanks Stefan!
Glad to hear it. All credits to Lee Mac.
