Hi,
Is there any LISP to Unload all XREF?
Thank you.
(vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
 (if (= (vla-get-isxref block) :vlax-true) (vla-unload block))
How can I use it?
I have tried to defun c: TEST () ; and I have put the code but it doesn't work.
I am not a specialist of AutoLISP :?
Thank you.
Sorry.. Try this
(defun c:test nil (vl-load-com)
Thank you Stefan BMR :)
I have found this also:
(defun c:XDetach (/ blk)  (while   (setq blk (tblnext "block" (not blk)))   (if (and (cdr (assoc 1 blk))            (< (cdr (assoc 70 blk)) 32))     (command "_-xref" "_d" (cdr (assoc 2 blk))))  ) )
  • 1 month later...
one I found
xu.lsp
(defun C:Xu ( / )
(command "-xref" "u" "*")
one I found
[ATTACH]51388[/ATTACH]
(defun C:Xu ( / )
(command "-xref" "u" "*") what does "*" this do ? and where else we can use "*" this.
It means ALL or ANY. It is a wildcard search or selection symbol. It can be used pretty much anywhere you want to find or select ALL.
