Hello,
for a project I needed to find the shortest way between two points in a network, so I searched for a pathfinding algorithm in AutoLISP. Since I did not find anything - here comes my implementation of the A* pathfinding algorithm. (If you don't know what A* is - I got my information here: http://en.wikipedia.org/wiki/A*_search_algorithm)
The program finds the shortest way in a network of polylines between two points, the polylines representing the paths you are allowed to move along. Two polylines are considered connected if one of their vertices match. The resulting path is returned as a new polyline.
The program and a test.dwg are attached to this post.
I would like to extent the network/edges in a way, that polylines are also considered connected if the vertice of one of them is on the line of another. I could use some help with that.
I hope this is useful for someone.
astar_01.lsp
test_01.dwg
Edited by heschr
  • 4 years later...
This is Amazing work!, but what if there were multiple Objectives? Could there be a way to create a multi-objective pathfinder? For example In HVAC; Say If the Staring point is Given, But I want to Route my ducts to multiple Registers, Is there a way A* could do that?
  • 6 years later...
Here I've revised Helmut's code and made it faster.
;; Pathfinding with the A* algorithm      by ymg 22/07/2024                   ;
;; Revised a prog by  HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14            ;
;; found at Cadtutor.net                                                      ;
;; Kept the same format for edges list but added lines as valid choice        ;
;; Format: (((x1 y1) (x2 y2)) (((x2 y2) (x3 y3))....(xn yn)))                 ;
;; The user is asked to pick a start and an endpoint.                         ;
;; The program will find the shortest path in a network of connected          ;
;; polylines and/or lines and draw a new polyline representing the result.    ;
;; Two lists of nodes openlst and closelst are created from the above         ;
;; mentionned edges list. The format of a node list is:                       ;
;;  (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...)   ;
;; Main change from origina are:                                              ;
;;   - cons the list instead of append                                        ;
;;   - vl-sort the openlist instead of the quicksort                          ;
;;   - Replaced and renamed some vars and subroutine.                         ;
;;   - Added fuzz 1e-4 to all points comparison                               ;
;;   - Change the get_path function                                           ;
;;   - Added line as possible edges                                           ;
;;   - Added an error handler                                                 ;
;;   - Added a timer to the search portion of the program                     ;
;; The above changes amounted to an acceleration of about 4x from the         ;
;; original program.                                                          ;
;; If you compile this program to a .fas you'll get more than 10x faster.     ;
(defun c:A* ( / ssl ssp i edges startp endp openlst closelst found acdoc Edgelay Pathlay Pathcol Pathlwt)
  (vl-load-com)
  ; Changes values of following 4 global variables to suit your need.         ;
  (setq Edgelay "Edges"
        Pathlay "Path"
	Pathcol 1       ; 1=Red 2=Yellow   etc.           ;
	Pathlwt 70      ; lineweight for path  0.7mm      ;
  (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
  (set_errhandler '("CLAYER" "OSMODE" "CMDECHO"))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE  1)
  (if (setq ssp (ssget '"X" (list (cons 0  "LWPOLYLINE") (cons 8  Edgelay))))
      (foreach en (mapcar (function cadr) (ssnamex ssp))
        (setq edges (append edges (mk_edge (listpol2d en))))
  (if (setq ssl (ssget '"X" (list (cons 0  "LINE") (cons 8  Edgelay))))
     (foreach en (mapcar (function cadr) (ssnamex ssl))
        (setq edges (cons  (list (butlast (vlax-curve-getstartpoint en)) (butlast (vlax-curve-getendpoint en))) edges))
  (setq startp  (butlast (getpoint "\nPick Start Point: "))                 ; Startpoint - reduced to 2D                      ;
        endp    (butlast (getpoint "\nPick End Point: "))                   ; Endpoint   - reduced to 2D                      ;
        openlst (list (list startp '(0 0) 0.0 (distance startp endp)))      ; Add starting node to openlst                    ;
  (vla-startundomark acdoc)
  (setq ti (getvar 'MILLISECS))
  (while (and openlst (not found))
     (setq node (car openlst))
     (if (equal (car node) endp 1e-4)
        (setq found T  closelst (cons node closelst))
        (setq closelst (cons node closelst)
	      openlst  (upd_openlst edges node endp (cdr openlst) closelst)
  (if found
    (mk_lwp (get_path closelst))
    (alert "No path was found")
  (princ (strcat "\nExecution time:" (itoa (- (getvar 'MILLISECS) ti)) " milliseconds."))
  (*error* nil)
;; upd_openlst        ;
;; Each node of the openlst is passed to this sub and we scan the edges list  ;
;; to find the corresponding edges. Then both points of the edges are tested  ;
;; for equality to the nodes.  The fixed cost (distance) is updated and so is ;
;; the estimated total distance. Updates are first put in a temporary node.   ;
;; We then proceed to test if the temp variable is already in the closelst    ;
;; and proceed to the next edge.                                              ;
;; If temp is true and temp is not in closelst we go to the recursive sub     ;
;; in_openlst which adjust the values and return the updated openlst          :
;; Upon return we sort the openlst on smallest estimated distance             ;
;; and return the openlst to the main routine                                 ;
(defun upd_openlst (edges node endp openlst closelst / pt fcost p1 p2 d temp)
  (setq pt (car node)  fcost (caddr node))
  (while edges
    (setq p1 (caar edges) p2 (cadar edges) edges (cdr edges) d (distance p1 p2) temp nil)
    ;Testing both points of an edge and building a temporary node             ;
    (cond
      ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))))
      ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp)))))
    (if (and temp (not (memberfuzz (car temp) closelst)))
      (setq openlst (in_openlst temp openlst))
  ; Keep openlist sorted on smallest Estimated Total Cost                     ;
  (print (vl-sort openlst (function (lambda(a b)(< (cadddr a) (cadddr b))))) )
;in_lst  Replaced by memberfuzz                                               ;
;(defun in_lst (pt lst)
;  (cond
;     ((not lst) nil)
;     ((equal pt (caar lst) 1e-4) lst)
;     (T (in_lst pt (cdr lst)))
; returns a new openlst with a double exchanged if cost is lower              ;
(defun in_openlst (node lst)
  (cond
    ((not lst) (list node))
    ((equal (car node) (caar lst) 1e-4)
      (if (< (cadddr node) (cadddr (car lst)))
        (cons node (cdr lst))
        lst
    (T (cons (car lst) (in_openlst node (cdr lst))))
(defun in_openlst2 (node lst / s c)
   (setq s (splitat (caar node) lst) c (cadddr node))
   (cond
      ((not (car s)) (cons node (cadr s)))
      ((not (cadr s)) (cons node (car s)))
      (T (if (< (cadddr node) (cadddr (cadr s)))
	    (append (car s) (cons node (cdr s)))
	    lst
      ;(T (c ns node lst))
;; listpol2D   by ymg    (Simplified a Routine by Gile Chanteau               ;
;; Parameter:  en,  Entity Name or Object Name of Any Type of Polyline        ;
;; Returns:    List of Points in 2D WCS                                       ;
;; Notes:      Requires butlast function for 2d points.                       ;
(defun listpol2d (en / i lst)
  (repeat (setq i (fix (1+ (vlax-curve-getEndParam en))))
     (setq lst (cons (butlast (vlax-curve-getPointAtParam en (setq i (1- i)))) lst))
;; mk_edge        ;
;; From a list of consecutives points as supplied by listpol2D,               ;
;; Returns a list of edges  (((x1 y1)(x2 y2)) ((x2 y2)(x3 y3))...)            ;
(defun mk_edge (lst)
  (mapcar (function (lambda (a b) (list a b ))) lst (cdr lst))
;; butlast        ;
;; Returns a list without the last item                                       ;
;; Used here mainly to change points to 2D                                    ;
(defun butlast (lst) (reverse (cdr (reverse lst))))
;; get_path        ;
;; Returns The list of points of shortest path found from closelst.           ;
(defun get_path (lst / path)
  (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst))
  (while (setq lst  (memberfuzz prev lst))
     (setq prev (cadar lst)
           path (cons (caar lst) path)
  path
;; memberfuzz  by Gile Chanteau                                               ;
;; Modified to work with nodes list                                           ;
(defun memberfuzz (p lst)
  (while (and lst (not (equal p (caar lst)  1e-4)))
    (setq lst (cdr lst))
  lst
(defun splitat (p lst / tr)
    (setq tr (cons (car lst) tr) lst (cdr lst))
  (list (reverse tr) lst)
(defun truncfuzz (p lst)
  (if (and lst (not (equal p (caar lst) 1e-4)))
    (cons (car lst) (truncfuzz p (cdr lst)))
(defun posfuzz (p lst)
  (- (length lst) (length (memberfuzz p lst)))
(defun rotleft  (lst) (append (cdr lst) (list (car lst))))
(defun rotright (lst) (cons (last lst) (butlast lst)))
;; mk_lwp        ;
;; Draw an lwpolyline given a point list                                      ;
;; Will be drawn on layer with color and lineweight defined by Variables      ;
;; at beginnung of program.                                                   ;
(defun mk_lwp (pl)
  (entmakex
    (append
      (list
        (cons 100 "AcDbEntity")
        (cons 100 "AcDbPolyline")
	(cons 8    Pathlay)
	(cons 62   Pathcol)
        (cons 90   (length pl))
        (cons 70   0)
	(cons 370  Pathlwt)
      (mapcar (function (lambda (a) (cons 10 a))) pl)
;; Error Handler        by Elpanov Evgenyi                                    ;
(defun set_errhandler (l)
   (setq varl (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) l))
(defun *error* (msg)
   (mapcar 'eval varl)
   (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")))
   (vla-endundomark acdoc)
(princ "A* to start")
Astar rev3.lsp astar test.dwg
  • Like 3
  • Agree 2
  • Thanks 1
I think this is an extremely interesting problem that deserves significantly more lines of code than have been written so far in this thread.
I believe those lines shouldn't be long in coming.
  • Like 2
I know this query is old, but...
Maybe for the path to multiple locations use the Traveling Salesman Problem (TSP) algorithm. @marko_ribar has a LISP on CADTutor.
Bellman-Ford algorithm can handle the shortest path from a single source to all other nodes might work.
  • 2 months later...
Hi
I've attached a small revision of @ymg3's excellent code that further improves speed.
Tested on this drawing (3200 polylines)
Ax.dwg
Added or revised code by GLAVCVS (january 2026)
	-All set are grouped into one
	-An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions)
	-The "edges" list is replaced with the local search retourned by 'getCell'
 T E S T S =====
 	fas:  4-5 x faster than previous fas
 	lsp:  7-8 x faster than previous lsp
(defun c:A* (/ sspl	 i	   edges     startp    endp
	       Pathlay	 Pathcol   Pathlwt   lstClvs
  (vl-load-com)
  (setq	Edgelay	"0"
	Pathlay	"0"
  (or acdoc
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 1)
;;;  (if (setq
;;;	ssp (ssget '"X" (list (cons 0 "LWPOLYLINE") (cons 8 Edgelay)))
;;;    (foreach en	(mapcar (function cadr) (ssnamex ssp))
;;;      (addToDict en)
;;;      (setq edges (append edges (mk_edge (listpol2d en))))
;;;    nil
;;;  (if (setq ssl (ssget '"X" (list (cons 0 "LINE") (cons 8 Edgelay))))
;;;    (foreach en	(mapcar (function cadr) (ssnamex ssl))
;;;      (setq edges (cons	(list (butlast (vlax-curve-getstartpoint en))
;;;			      (butlast (vlax-curve-getendpoint en))
;;;			edges
;;;ADDED by GLAVCVS
  (if (setq sspl (ssget "X" (list '(0 . "*LINE") (cons 8 EdgeLay))))
    (foreach en	(mapcar (function cadr) (ssnamex sspl))
      (addToDict en)
      (setq found    T
  (if found
		 " milliseconds."
  (*error* nil)
;;;ADDED by GLAVCVS
;;;Create dictionary
(defun addToDict (en / p1 p2 id clv)
  (setq p1 (vlax-curve-getStartPoint en)
	p2 (vlax-curve-getEndPoint en)
	id (cdr (assoc 5 (entget en)))
  (foreach p (list p1 p2)
    (if (setq val (assoc (setq clv (strcat (itoa (fix (car p))) "-" (itoa (fix (cadr p))))) lstClvs))
      (setq lstClvs (subst (append val (list id)) val lstClvs))
      (setq lstClvs (cons (list clv id) lstClvs))
;;;return list cell
(defun getCell (pt / clv v lr)
  (if (setq val (assoc (setq clv (strcat (itoa (fix (car pt))) "-" (itoa (fix (cadr pt))))) lstClvs))
    (foreach e (cdr val)
      (setq lr (cons (list (butlast (vlax-curve-getStartPoint (handent e))) (butlast (vlax-curve-getEndPoint (handent e)))) lr))
;; upd_openlst        ;
(defun upd_openlst
       (edges node endp openlst closelst / lEdges edge pt fcost p1 p2 d temp)
  (setq	pt    (car node)
	fcost (caddr node)
;;;added By GLAVCVS
  (setq lEdges (getCell pt))
  (foreach edge lEdges
    (setq p1 (car edge)
          p2 (cadr edge)
          d	(distance p1 p2)
	  temp	nil
;;;  (while edges
;;;    (setq p1	(caar edges)
;;;	  p2	(cadar edges)
;;;	  edges	(cdr edges)
;;;	  d	(distance p1 p2)
;;;	  temp	nil
    (cond
      ((equal pt p1 1e-4)
      ((equal pt p2 1e-4)
       (setq
  (vl-sort openlst
	   (function (lambda (a b) (< (cadddr a) (cadddr b))))
					;  (cond
					;     ((not lst) nil)
  (cond
       lst
	c (cadddr node)
  (cond
    (T
       lst
    (setq lst
		 lst
;; mk_edge        ;
  (mapcar (function (lambda (a b) (list a b))) lst (cdr lst))
;; butlast        ;
;; get_path        ;
	prev (cadar lst)
	lst  (cdr lst)
  path
  lst
	  lst (cdr lst)
;; mk_lwp        ;
(defun mk_lwp (pl)
  (entmakex
    (append
      (list
	(cons 8 Pathlay)
	(cons 62 Pathcol)
	(cons 70 0)
	(cons 370 Pathlwt)
  (setq
		 l
  (mapcar 'eval varl)
  (if (and msg
Edited by GLAVCVS
Delete unnecessary code
  • Like 2
Never tried the dict trick to accelerate the retrieval but it seems a good idea.  However as of your last edited code the path found is erroneous.  See the attached image.
It's difficult to know what's happening there without the original drawing and without knowing the starting and ending points.
I reproduced that drawing from your image and ran the code without any problems.
But perhaps I'm wrong.
PS: Anyway, try your code on this drawing (mine will return the same result because it only speeds up the process).
YMG3.dwg
I've left a yellow line on a different layer from the rest so that it's outside the selection set, and the start and end points are marked with little circles.
The original drawing is attached with my post as AStar Test.dwg.  Start point is upper left.
ymg
astar test.dwg
Also you must realize that if two polylines crosses the intersection point is not necessarily a node.
ymg
Edited by ymg3
I thought it was a given that all intersections necessarily divide the polylines.
I must admit I didn't see your drawing until now.
I apologize for that.
I've attached modified code to fix this.
Added or modified code by GLAVCVS (january 2026)
 T E S T S =====
  (vl-load-com)
  (setq	Edgelay	"0"
	Pathlay	"0"
  (or acdoc
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 1)
;;;  (if (setq
;;;      (addToDict en)
;;;    nil
;;;			edges
;;;ADDED by GLAVCVS
      (addToDict en)
    (setq node (car openlst)); coge el primero (el que más progresa)
      (setq found    T
  (if found
		 " milliseconds."
  (*error* nil)
;;;ADDED by GLAVCVS
;;*** Modified to consider all segments within any polyline ***
(defun addToDict (en / p1 p2 id clv i)
  (setq i -1 id (cdr (assoc 5 (entget en))))
  (while (setq p (vlax-curve-getPointAtParam en (setq i (1+ i))))
      (setq lstClvs (subst (append val (list (cons id i))) val lstClvs))
      (setq lstClvs (cons (list clv (cons id i)) lstClvs))
;;;return list cell
;;*** Modified to access the new dictionary format ***
(defun getCell (pt / clv v lr id p pr par)
    (foreach par (cdr val)
      (setq e (handent (car par)))
      (if (zerop (setq pr (cdr par)))
	(setq lr (cons (list (butlast (vlax-curve-getPointAtParam e pr)) (butlast (vlax-curve-getPointAtParam e (1+ pr)))) lr))
	(setq lr (cons (list (butlast (vlax-curve-getPointAtParam e (1- pr))) (butlast (vlax-curve-getPointAtParam e pr))) lr)
	      lr (if (setq p (vlax-curve-getPointAtParam e (1+ pr))) (cons (list (butlast (vlax-curve-getPointAtParam e pr)) (butlast p)) lr) lr)
;; upd_openlst        ;
(defun upd_openlst
  (setq	pt    (car node)
	fcost (caddr node)
;;;added By GLAVCVS
    (setq p1 (car edge)
          p2 (cadr edge)
          d	(distance p1 p2)
	  temp	nil
;;;  (while edges
;;;	  temp	nil
    (cond
      ((equal pt p1 1e-4)
       ;                p  p0  distAcum   (distAcum + distRestante)
      ((equal pt p2 1e-4)
       (setq
    (if	(and temp (not (memberfuzz (car temp) closelst))); si el punto en avance candidato no está ya en 'closelst'
  (vl-sort openlst
	   (function (lambda (a b) (< (cadddr a) (cadddr b)))) ;ordena los coincidentes por orden de progresión hacia destino
					;  (cond
					;     ((not lst) nil)
  (cond
    ((equal (car node) (caar lst) 1e-4); si el primer elemento de 'node' (punto) es igual que el primero del primer elemento de 'lst'
     (if (< (cadddr node) (cadddr (car lst))); si (distancia acumulada + restante) es menor en 'node' que en '(car lst)'
       lst
	c (cadddr node)
  (cond
    (T
       lst
    (setq lst
		 lst
;; mk_edge        ;
;; butlast        ;
;; get_path        ;
	prev (cadar lst)
	lst  (cdr lst)
  path
  lst
	  lst (cdr lst)
;; mk_lwp        ;
(defun mk_lwp (pl)
  (entmakex
    (append
      (list
	(cons 8 Pathlay)
	(cons 62 Pathcol)
	(cons 70 0)
	(cons 370 Pathlwt)
  (setq
		 l
  (mapcar 'eval varl)
  (if (and msg
👍Looks OK to me, and a nice acceleration.
ymg
Edited by ymg3
