52 minutes ago, GLAVCVS said:
"I think I understand the problem now.
But it only happens with lines. With polylines, whether 3D or not, this doesn't happen.
The issue is that "getPointAtParam" doesn't work the same way with lines as it does with polylines.
If param=1, it doesn't return the expected result.
I've modified the code to fix this (I think)
 @GLAVCVS Now you know why I had two different selection set for lines and polylines.
ymg
I agree with ymg and thanks for improvement ab Dictionary... Nevertheless, IMHO the general case is to perform A* with 3D entities, so 3D polyline is my preferable result... You can explode polylines, select LINES in 2D, or 3D and perform A*; with my version you'll get 3D POLYLINE, after which you can just COPYBASE it with 0,0,0 base and put it into clipboard... Then, do several UNDO until before you exploded anything... Finally, you PASTECLIP with 0,0,0 from clipboard and if network was 3D, then 3D POLYLINE should be just fine, and if network was 2D, you explode 3D POLYLINE into LINE segments, and just do JOIN command on Previous selection - you'll get LWPOLYLINE to which you should just manually adjust lineweight... That's all, simple and unexaustive procedure... BTW., your filter '(0 . "*LINE") in acquirying selection sspl also involves SPLINE entities, for which A* isn't adequate... Perhaps, you should do it with '(0 . "LINE,LWPOLYLINE,POLYLINE") as proper filter... Little robust, but appropriate...
@marko_ribar The 3d is a nice addition, but the general case is 2d in the context of graph.  Your suggestion for the filter is indeed more robust.
ymg
Edited by ymg3
I forgot to include the creation of the 3D polyline.
This last code creates the path in 2D or 3D as needed.
;; Pathfinding with the A* algorithm      by ymg 22/07/2024                   ;
;; Revised a prog by  HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14            ;
;; found at Cadtutor.net                                                      ;
;; Kept the same format for edges list but added lines as valid choice        ;
;; Format: (((x1 y1) (x2 y2)) (((x2 y2) (x3 y3))....(xn yn)))                 ;
;; The user is asked to pick a start and an endpoint.                         ;
;; The program will find the shortest path in a network of connected          ;
;; polylines and/or lines and draw a new polyline representing the result.    ;
;; Two lists of nodes openlst and closelst are created from the above         ;
;; mentionned edges list. The format of a node list is:                       ;
;;  (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...)   ;
;; Main change from origina are:                                              ;
;;   - cons the list instead of append                                        ;
;;   - vl-sort the openlist instead of the quicksort                          ;
;;   - Replaced and renamed some vars and subroutine.                         ;
;;   - Added fuzz 1e-4 to all points comparison                               ;
;;   - Change the get_path function                                           ;
;;   - Added line as possible edges                                           ;
;;   - Added an error handler                                                 ;
;;   - Added a timer to the search portion of the program                     ;
;; The above changes amounted to an acceleration of about 4x from the         ;
;; original program.                                                          ;
;; If you compile this program to a .fas you'll get more than 10x faster.     ;
Added or revised code by GLAVCVS (january 2026)
	-All set are grouped into one
	-An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions)
	-The "edges" list is replaced with the local search retourned by 'getCell'
 T E S T S =====
 	fas:  4-5 x faster than previous fas
 	lsp:  7-8 x faster than previous lsp
(defun c:A* (/ sspl	 i	   edges     startp    endp
	       openlst	 closelst  found     acdoc     Edgelay
	       Pathlay	 Pathcol   Pathlwt   lstClvs   path
  (vl-load-com)
  					; Changes values of following 4 global variables to suit your need.         ;
  (setq	Edgelay	"0"
	Pathlay	"0"
	Pathcol	1			; 1=Red 2=Yellow   etc.           ;
	Pathlwt	70			; lineweight for path  0.7mm      ;
  (or acdoc
      (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  (set_errhandler '("CLAYER" "OSMODE" "CMDECHO"))
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 1)
;;;  (if (setq
;;;	ssp (ssget '"X" (list (cons 0 "LWPOLYLINE") (cons 8 Edgelay)))
;;;    (foreach en	(mapcar (function cadr) (ssnamex ssp))
;;;      (addToDict en)
;;;      (setq edges (append edges (mk_edge (listpol2d en))))
;;;    nil
;;;  (if (setq ssl (ssget '"X" (list (cons 0 "LINE") (cons 8 Edgelay))))
;;;    (foreach en	(mapcar (function cadr) (ssnamex ssl))
;;;      (setq edges (cons	(list (butlast (vlax-curve-getstartpoint en))
;;;			      (butlast (vlax-curve-getendpoint en))
;;;			edges
;;;ADDED by GLAVCVS
  (if (setq sspl (ssget "X" (list '(0 . "*LINE") (cons 8 EdgeLay))))
    (foreach en	(mapcar (function cadr) (ssnamex sspl))
      (addToDict en)
  (setq	startp	(getpoint "\nPick Start Point: ")
					; Startpoint                    ;
	endp	(getpoint "\nPick End Point: ")
					; Endpoint                      ;
	openlst	(list (list startp '(0 0 0) 0.0 (distance startp endp)))
					; Add starting node to openlst                    ;
  (vla-startundomark acdoc)
  (setq ti (getvar 'MILLISECS))
  (while (and openlst (not found))
    (setq node (car openlst)); coge el primero (el que más progresa)
    (if	(equal (car node) endp 1e-4)
      (setq found    T
	    closelst (cons node closelst)
      (setq closelst (cons node closelst)
	    openlst  (upd_openlst edges node endp (cdr openlst) closelst)
  (if found
    (if (vl-some '(lambda(x) (not (equal (last x) 0.0 1e-3))) (setq path (get_path closelst)))
      (f3Dpol path Pathcol)
      (mk_lwp path)
    (alert "No path was found")
  (princ (strcat "\nExecution time:"
		 (itoa (- (getvar 'MILLISECS) ti))
		 " milliseconds."
  (*error* nil)
;;;ADDED by GLAVCVS
;;;Create dictionary
;;;[Modified to consider all segments within any polyline]
(defun addToDict (en / p1 p2 id clv i l c a)
  (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (cdr (assoc 0 l)) "LINE") a 10)
  (while (setq p (if (and (setq i (1+ i)) c) (cdr (assoc (+ a i) l)) (vlax-curve-getPointAtParam en i)))
    (if (setq val (assoc (setq clv (strcat (itoa (fix (car p))) "-" (itoa (fix (cadr p))))) lstClvs))
      (setq lstClvs (subst (append val (list (cons id i))) val lstClvs))
      (setq lstClvs (cons (list clv (cons id i)) lstClvs))
;;;return list cell
(defun getCell (pt / clv v lr id p p0 pr par l c oc)
  (defun oc (c e i) (if c (cdr (assoc (+ i 10) l)) (vlax-curve-getPointAtParam e i)))
  (if (setq val (assoc (setq clv (strcat (itoa (fix (car pt))) "-" (itoa (fix (cadr pt))))) lstClvs))
    (foreach par (cdr val)
      (setq e (handent (car par)) c (= (cdr (assoc 0 (setq l (entget e)))) "LINE"))
      (if (zerop (setq pr (cdr par)))
	(setq lr (cons (list (oc c e pr) (oc c e (1+ pr))) lr))
	(setq lr (cons (list (oc c e (1- pr)) (setq p0 (oc c e pr))) lr)
	      lr (if (setq p (oc c e (1+ pr))) (cons (list p0 p) lr) lr)
;; upd_openlst        ;
;; Each node of the openlst is passed to this sub and we scan the edges list  ;
;; to find the corresponding edges. Then both points of the edges are tested  ;
;; for equality to the nodes.  The fixed cost (distance) is updated and so is ;
;; the estimated total distance. Updates are first put in a temporary node.   ;
;; We then proceed to test if the temp variable is already in the closelst    ;
;; and proceed to the next edge.                                              ;
;; If temp is true and temp is not in closelst we go to the recursive sub     ;
;; in_openlst which adjust the values and return the updated openlst          :
;; Upon return we sort the openlst on smallest estimated distance             ;
;; and return the openlst to the main routine                                 ;
(defun upd_openlst
       (edges node endp openlst closelst / lEdges edge pt fcost p1 p2 d temp)
  (setq	pt    (car node)
	fcost (caddr node)
;;;added By GLAVCVS
  (setq lEdges (getCell pt))
  (foreach edge lEdges
    (setq p1 (car edge)
          p2 (cadr edge)
          d	(distance p1 p2)
	  temp	nil
;;;  (while edges
;;;    (setq p1	(caar edges)
;;;	  p2	(cadar edges)
;;;	  edges	(cdr edges)
;;;	  d	(distance p1 p2)
;;;	  temp	nil
					;Testing both points of an edge and building a temporary node             ;
    (cond
      ((and (equal pt p1 1e-4) (not (memberfuzz p2 closelst)))
       (setq openlst (in_openlst (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp))) openlst))
;;;       (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp))))
      ((and (equal pt p2 1e-4) (not (memberfuzz p1 closelst)))
       (setq openlst (in_openlst (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp))) openlst))
;;;       (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp))))
;;;    (if	(and temp (not (memberfuzz (car temp) closelst)))
;;;      (setq openlst (in_openlst temp openlst))
					; Keep openlist sorted on smallest Estimated Total Cost                     ;
  (vl-sort openlst
	   (function (lambda (a b) (< (cadddr a) (cadddr b))))
					;in_lst  Replaced by memberfuzz                                               ;
					;(defun in_lst (pt lst)
					;  (cond
					;     ((not lst) nil)
					;     ((equal pt (caar lst) 1e-4) lst)
					;     (T (in_lst pt (cdr lst)))
					; returns a new openlst with a double exchanged if cost is lower              ;
(defun in_openlst (node lst)
  (cond
    ((not lst) (list node))
    ((equal (car node) (caar lst) 1e-4)
     (if (< (cadddr node) (cadddr (car lst)))
       (cons node (cdr lst))
       lst
    (T (cons (car lst) (in_openlst node (cdr lst))))
(defun in_openlst2 (node lst / s c)
  (setq	s (splitat (caar node) lst)
	c (cadddr node)
  (cond
    ((not (car s)) (cons node (cadr s)))
    ((not (cadr s)) (cons node (car s)))
    (T
     (if (< (cadddr node) (cadddr (cadr s)))
       (append (car s) (cons node (cdr s)))
       lst
					;(T (c ns node lst))
;; listpol2D   by ymg    (Simplified a Routine by Gile Chanteau               ;
;; Parameter:  en,  Entity Name or Object Name of Any Type of Polyline        ;
;; Returns:    List of Points in 2D WCS                                       ;
;; Notes:      Requires butlast function for 2d points.                       ;
(defun listpol2d (en / i lst)
  (repeat (setq i (fix (1+ (vlax-curve-getEndParam en))))
    (setq lst
	   (cons (butlast (vlax-curve-getPointAtParam en (setq i (1- i))))
		 lst
;; mk_edge        ;
;; From a list of consecutives points as supplied by listpol2D,               ;
;; Returns a list of edges  (((x1 y1)(x2 y2)) ((x2 y2)(x3 y3))...)            ;
(defun mk_edge (lst)
  (mapcar (function (lambda (a b) (list a b))) lst (cdr lst))
;; butlast        ;
;; Returns a list without the last item                                       ;
;; Used here mainly to change points to 2D                                    ;
(defun butlast (lst) (reverse (cdr (reverse lst))))
;; get_path        ;
;; Returns The list of points of shortest path found from closelst.           ;
(defun get_path	(lst / path)
  (setq	path (list (caar lst))
	prev (cadar lst)
	lst  (cdr lst)
  (while (setq lst (memberfuzz prev lst))
    (setq prev (cadar lst)
	  path (cons (caar lst) path)
  path
;; memberfuzz  by Gile Chanteau                                               ;
;; Modified to work with nodes list                                           ;
(defun memberfuzz (p lst)
  (while (and lst (not (equal p (caar lst) 1e-4)))
    (setq lst (cdr lst))
  lst
(defun splitat (p lst / tr)
    (setq tr  (cons (car lst) tr)
	  lst (cdr lst)
  (list (reverse tr) lst)
(defun truncfuzz (p lst)
  (if (and lst (not (equal p (caar lst) 1e-4)))
    (cons (car lst) (truncfuzz p (cdr lst)))
(defun posfuzz (p lst)
  (- (length lst) (length (memberfuzz p lst)))
(defun rotleft (lst) (append (cdr lst) (list (car lst))))
(defun rotright (lst) (cons (last lst) lst))
   ;Added by GLAVCVS
(defun f3Dpol (pts c / doc ep ll la e x)
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))
        ep (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace doc) (vla-get-ModelSpace doc))
        ll (apply 'append pts)
        la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar 'float ll))
	e (vla-Add3DPoly ep la)
	x (vla-put-Color e c)
;; mk_lwp        ;
;; Draw an lwpolyline given a point list                                      ;
;; Will be drawn on layer with color and lineweight defined by Variables      ;
;; at beginnung of program.                                                   ;
(defun mk_lwp (pl)
  (entmakex
    (append
      (list
	(cons 100 "AcDbEntity")
	(cons 100 "AcDbPolyline")
	(cons 8 Pathlay)
	(cons 62 Pathcol)
	(cons 90 (length pl))
	(cons 70 0)
	(cons 370 Pathlwt)
      (mapcar (function (lambda (a) (cons 10 a))) pl)
;; Error Handler        by Elpanov Evgenyi                                    ;
(defun set_errhandler (l)
  (setq
    varl (mapcar (function (lambda (a) (list 'setvar a (getvar a))))
		 l
(defun *error* (msg)
  (mapcar 'eval varl)
  (if (and msg
	   (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
  (vla-endundomark acdoc)
Edited by GLAVCVS
  • Like 3
On 1/27/2026 at 8:04 PM, GLAVCVS said:
PS: Anyway, try your code on this drawing (mine will return the same result because it only speeds up the process).
I've left a yellow line on a different layer from the rest so that it's outside the selection set, and the start and end points are marked with little circles.
Hello everyone.
It's been a long time since I first visited this forum, but I didn't register until recently. Perhaps it's because of some interesting topics I've seen here lately 😊
Regarding this previous post, I think I finally understand: the path returned by the code isn't the shortest in this drawing.
What's going on here?
Is this one of the cases where A* can escape?
Or is it a bug in the code?
Thank you so much for being here and sharing your time and knowledge 🙂
Edited by malintzin
Hi, it's me again... I've implemented lastly coded interventions by @GLAVCVS into my cleaned version... It should work well with user selection of network entities... Still filter for selection is now very robust, but it seems that it should be coded like that (I don't know how to make it better - shorter)... I think that this version fulfills any situation that may occur LINES, POLYLINES (2D-Heavy, 3D), LWPOLYLINES (without arced segments).
If you see something I missed, please don't hasitate to inform - post reply...
;; Format: (((x1 y1 z1) (x2 y2 z2)) ((x2 y2 z2) (x3 y3 z3))....)              ;
;; lines and draw a new 3dpolyline representing the result.                   ;
Added or modified code by GLAVCVS (january 2026)
 T E S T S =====
(defun c:A* (/ *error*      addToDict    getCell     upd_openlst
               in_openlst   get_path     memberfuzz  mk_lwp
               f3Dpol       LM:rtos      set_errhandler
               sspl         i         startp    endp      e
               openlst      closelst  found     acdoc     lstClvs
               Pathlay      Pathcol   Pathlwt   varl      node
               ti
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
    (if e
      (if command-s
        (command-s "_.draworder" e "" "_f")
        (vl-cmdf "_.draworder" e "" "_f")
    (mapcar (function eval) varl)
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")))
  ;;;ADDED by GLAVCVS
  (defun addToDict (en / p val id clv i l c a)
      (if (setq val (assoc (setq clv (strcat (LM:rtos (car p) 2 4) "," (LM:rtos (cadr p) 2 4) "," (LM:rtos (caddr p) 2 4))) lstClvs))
  ;;;return list cell
  ;;*** Modified to access the new dictionary format ***
  (defun getCell (pt / val clv lr pr par l c oc p0 p)
    (if (setq val (assoc (setq clv (strcat (LM:rtos (car pt) 2 4) "," (LM:rtos (cadr pt) 2 4) "," (LM:rtos (caddr pt) 2 4))) lstClvs))
  ;; upd_openlst        ;
  ;; in_openlst which adjust the values and return the updated openlst                            ;
  (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d temp)
    (setq pt    (car node)
          fcost (caddr node)
      (setq p1 (car edge)
            p2 (cadr edge)
            d (distance p1 p2)
            temp nil
      (cond
        ((equal pt p1 1e-4)
        ((equal pt p2 1e-4)
    (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b)))))
    (cond
         lst
      (t (cons (car lst) (in_openlst node (cdr lst))))
  ;; get_path        ;
          prev (cadar lst)
          lst  (cdr lst)
    path
    lst
  ;; f3Dpol        ;
  ;; Draw an 3dpolyline given a point list                                                        ;
  ;; Will be drawn on layer, lineweight and color defined by Variables                            ;
  (defun f3Dpol (pts c / ep ll la e)
    (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace acdoc) (vla-get-ModelSpace acdoc))
          ll (apply (function append) pts)
          la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar (function float) ll))
    (vla-put-Color e c)
    (vla-put-Layer e Pathlay)
    (vla-put-Lineweight e Pathlwt)
    (vlax-vla-object->ename e)
  ;; mk_lwp        ;
  (defun mk_lwp (pl)
    (entmakex
      (append
        (list
          (cons 8 Pathlay)
          (cons 62 Pathcol)
          (cons 70 (* 128 (getvar (quote plinegen))))
          (cons 370 Pathlwt)
  ;; A wrapper for the rtos function to negate the effect of DIMZIN   -  Lee Mac
  (defun LM:rtos (real units prec / dimzin result)
    (setq dimzin (getvar (quote dimzin)))
    (setvar (quote dimzin) 0)
    (setq result (vl-catch-all-apply (function rtos) (list real units prec)))
    (setvar (quote dimzin) dimzin)
    (if (not (vl-catch-all-error-p result))
      result
    (setq varl (mapcar (function (lambda (a) (list (quote setvar) a (getvar a)))) l))
  ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  ; Change values of following 3 variables to suit your need.                                     ;
  (setq Pathlay        "0"
        Pathcol        3                        ; 1=Red 2=Yellow 3=Green  etc.                    ;
        Pathlwt	       30                       ; lineweight for path 0.3 mm                      ;
  (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
  (set_errhandler (list "clayer" "osmode" "cmdecho"))
  (setvar (quote cmdecho) 0)
  (setvar (quote osmode) 1)
  (setvar (quote lwdisplay) 1)
  (prompt "\nSelect LINE and polygonal POLYLINE network entities...")
  (if (setq sspl (ssget (list (cons -4 "<or") (cons 0 "LINE") (cons -4 "<and") (cons 0 "POLYLINE") (cons -4 "<or") (cons 70 8) (cons 70 9) (cons 70 0) (cons 70 1) (cons 70 128) (cons 70 129) (cons -4 "or>") (cons -4 "and>") (cons -4 "<and") (cons 0 "LWPOLYLINE") (cons -4 "<not") (cons -4 "<>") (cons 42 0.0) (cons -4 "not>") (cons -4 "and>") (cons -4 "or>"))))
    (foreach en (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex sspl)))
      (addToDict en)
  (initget 1)
  (setq startp (getpoint "\nPick or specify Start Point : "))
  (initget 1)
  (setq endp (getpoint "\nPick or specify End Point : "))
  (setq openlst (list (list startp (list 0.0 0.0 0.0) 0.0 (distance startp endp))))
  (setq ti (getvar (quote millisecs)))
      (setq found t closelst (cons node closelst))
      (setq closelst (cons node closelst) openlst  (upd_openlst node endp (cdr openlst) closelst))
  (if found
    (if (vl-some (function (lambda (x) (not (equal (last x) 0.0 1e-4)))) (setq path (get_path closelst)))
      (setq e (f3Dpol path Pathcol))
      (setq e (mk_lwp path))
    (alert "No path was found...")
  (princ (strcat "\nExecution time : " (itoa (- (getvar (quote millisecs)) ti)) " milliseconds..."))
  (*error* nil)
HTH.
Regards, M.R.
Edited by marko_ribar
  • Like 3
On 1/29/2026 at 6:16 PM, malintzin said:
Hello everyone.
I must apologize for forgetting to reply to your comment.
Please forgive me for this.
Welcome to the forum.
Yes, that's right.
In the case of that drawing, the code doesn't return the shortest path. Perhaps it's a limitation of A* for drawings like this.
I think @ymg3 is the most qualified to answer this.
  • Like 2
The path found has to travel on edges not on points.  If your graph does not have edges on the diagonal of the nodes it cannot find that path.
ymg
  • Thanks 1
 T E S T S =====
               ti
    (if e
      (if command-s
  ;;;ADDED by GLAVCVS
  ;;;return list cell
  ;; upd_openlst        ;
    (setq pt    (car node)
          fcost (caddr node)
      (setq p1 (car edge)
            p2 (cadr edge)
            d (distance p1 p2)
            temp nil
      (cond
        ((equal pt p1 1e-4)
        ((equal pt p2 1e-4)
    (cond
         lst
  ;; get_path        ;
          prev (cadar lst)
          lst  (cdr lst)
    path
    lst
  ;; f3Dpol        ;
    (vla-put-Color e c)
  ;; mk_lwp        ;
  (defun mk_lwp (pl)
    (entmakex
      (append
        (list
          (cons 8 Pathlay)
          (cons 62 Pathcol)
          (cons 370 Pathlwt)
      result
  (setq Pathlay        "0"
      (addToDict en)
  (initget 1)
  (initget 1)
  (if found
  (*error* nil)
HTH.
Regards, M.R.
I took a look at your modifications to make the code more robust
I have to say that I didn’t think it would be possible to consider the presence of “splines” in the drawing. But I agree with including this filter in the current code.
As for the filters for “legacy” POLYLINEs and LWPOLYLINEs, the code wouldn’t need those filters if we accept the premise that only straight distances between points will be measured.
BUT: to also cover this possibility, I’ve introduced a new function and made some modifications that allow any “*LINE” to be included in the analysis (including any “POLYLINE” or “SPLINE”).
In this way, the filters for the selection set become, once again, much simpler.
This also allows the drawing to compute routes using curved linear objects (arcs are excluded for now).
Regarding the use of LM:rtos, I consider this optional for cases where small cells are desired, and this may introduce some drawbacks.
Moreover, using such small cells significantly harms execution speed.
I ran a comparison between the execution speed of your code and this new one I’m attaching, and yours is 3 x  slower.
Additionally, creating the matrix with your requirements is also quite slow.
 T E S T S =====
(february 8, 2026):
	-Added new function '·dist·' for measuring distances of curved segments
	-Added a new lightweight function 'glvFix' to prevent possible rounding mismatches
	-Several modifications to include in filters and matrix the necessary
	 compatibility with curved linear objects
(defun c:A** (/ *error*      addToDict    getCell     upd_openlst
               ti	    ·dist·     glvFix
    (if e
      (if command-s
  ;;;ADDED by GLAVCVS
      (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car p) 0.0001)) "," (itoa (glvFix (cadr p) 0.0001)) "," (itoa (glvFix (caddr p) 0.0001)))) lstClvs))
	;(setq val (assoc (setq clv (strcat (LM:rtos (car p) 2 4) "," (LM:rtos (cadr p) 2 4) "," (LM:rtos (caddr p) 2 4))) lstClvs))
  (defun ·dist· (l? e p1 p2) (if l? (vlax-curve-getEndParam e) (abs (- (vlax-curve-getDistAtParam e p1) (vlax-curve-getDistAtParam e p2)))))
  ;;;return list cell
    (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car pt) 0.0001)) "," (itoa (glvFix (cadr pt) 0.0001)) "," (itoa (glvFix (caddr pt) 0.0001)))) lstClvs))
	  (setq lr (cons (list c e pr (1+ pr)) lr))
          (setq lr (cons (list c e (1- pr) pr) lr)
                lr (if (vlax-curve-getPointAtParam e (1+ pr)) (cons (list c e pr (1+ pr)) lr) lr)
  ;; upd_openlst        ;
  (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d l? temp)
    (setq pt    (car node)
          fcost (caddr node)
      (setq l? (car edge);new
	    e (cadr edge);new
	    pr1 (caddr edge);new
            pr2 (cadddr edge);new
	    p1 (vlax-curve-getPointAtParam e pr1);new
	    p2 (if l? (vlax-curve-getEndPoint e) (vlax-curve-getPointAtParam e pr2));new
            d (·dist· l? e pr1 pr2);new
            temp nil
      (cond
        ((equal pt p1 1e-4)
        ((equal pt p2 1e-4)
    (cond
         lst
  ;; get_path        ;
          prev (cadar lst)
          lst  (cdr lst)
    path
    lst
  ;; f3Dpol        ;
  ;; at beginning of program.        ;
  ;;;ADDED by GLAVCVS
    (vla-put-Color e c)
  ;; mk_lwp        ;
  (defun mk_lwp (pl)
    (entmakex
      (append
        (list
          (cons 8 Pathlay)
          (cons 62 Pathcol)
          (cons 370 Pathlwt)
  (defun glvFix (r i / f f1) (if (= (setq f (fix r)) (setq f1 (fix (+ r i)))) f f1))
      result
  (setq Pathlay        "0"
  (if (setq sspl (ssget	'((0 . "*LINE"))))
      (addToDict en)
  (initget 1)
  (initget 1)
  (if found
  (*error* nil)
In any case, I haven’t tested the code thoroughly enough on drawings containing “splines” or other complex linear objects.
In addition, there may be some situations that may not be covered.
But it should work.
In any case, the code is open to any improvements anyone may want to make.
Best regards.
Edited by GLAVCVS
New function "glvFix"
  • Like 2
PS
I forgot one detail: the resulting route won't emulate the curves, if there are any.  It will simply draw straight segments.
I think I chose the wrong version from my test code in the previous release. There are some bugs that affect drawings containing splines.
This version should fix those bugs.
T E S T S =====
(february 8, 2026):
-Added a new function 'EBiPts' to control obtaining coordinates from LINE and SPLINE objects
		in_openlst get_path   memberfuzz mk_lwp	    f3Dpol
		LM:rtos	   set_errhandler	 sspl	    i
		startp	   endp	      e		 openlst    closelst
		found	   acdoc      lstClvs	 Pathlay    Pathcol
		Pathlwt	   varl	      node	 ti	    ·dist·
		glvFix
    (if e
      (if command-s
  ;;;ADDED by GLAVCVS
  (defun addToDict (en / p val id clv i l c a to sp pl)
    (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (setq to (cdr (assoc 0 l))) "LINE") sp (= to "SPLINE") pl (= to "POLYLINE")); a 10)
    (while (setq p (if (and (setq i (1+ i)) (or c sp pl)) (eBiPts en i) (vlax-curve-getPointAtParam en i)))
  (defun ·dist· (r e p1 p2) (if r (vlax-curve-getEndParam e) (abs (- (vlax-curve-getDistAtParam e p1) (vlax-curve-getDistAtParam e p2)))))
  ;;;return list cell
  (defun getCell (pt / val clv lr pr par l c oc p0 p to sp pl)
        (setq e (handent (car par)) c (= (setq to (cdr (assoc 0 (setq l (entget e))))) "LINE") sp (= to "SPLINE") pl (= to "POLYLINE"))
	  (setq lr (cons (list (cond (c "l") (sp "s") (pl "p")) e pr (1+ pr)) lr))
          (setq lr (cons (list (cond (c "l") (sp "s") (pl "p")) e (1- pr) pr) lr)
                lr (if ((if (or c sp pl) eBiPts vlax-curve-getPointAtParam) e (1+ pr)) (cons (list (cond (c "l") (sp "s") (pl "p")) e pr (1+ pr)) lr) lr)
  (defun eBiPts (e pr / v0 v1 lp)
    (cond ((zerop pr) (vlax-curve-getStartPoint e)) ((= pr 1) (vlax-curve-getEndPoint e)))
  ;; upd_openlst        ;
  (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d f e r temp)
    (setq pt    (car node)
          fcost (caddr node)
      (setq f (if (setq r (member (car edge) '("l" "s" "p"))) eBiPts vlax-curve-getPointAtParam);new
	    e (cadr edge);new
	    p1 (f e pr1);new
	    p2 (f e pr2);new
            d (·dist· r e pr1 pr2);new
            temp nil
      (cond
        ((equal pt p1 1e-4)
        ((equal pt p2 1e-4)
    (cond
         lst
  ;; get_path        ;
          prev (cadar lst)
          lst  (cdr lst)
    path
    lst
  ;; f3Dpol        ;
  ;;;ADDED by GLAVCVS
    (vla-put-Color e c)
  ;; mk_lwp        ;
  (defun mk_lwp (pl)
    (entmakex
      (append
        (list
          (cons 8 Pathlay)
          (cons 62 Pathcol)
          (cons 370 Pathlwt)
      result
  (setq Pathlay        "0"
      (addToDict en)
  (initget 1)
  (initget 1)
  (if found
  (*error* nil)
PS:
As I mentioned earlier, the object representing the route remains the same polyline as in the previous code examples.
Therefore, although the calculations did take curved segments into account, the final polyline marking the route will still draw straight segments.
Edited by GLAVCVS
In your addition the F3dpol subroutine will be quite slow for path with many vertices due to the (apply (function append) pts) actually 4 times slower than mk_3dp. If you insist on going visual lisp the following would be faster by a factor of 2.  Note that variable beginning ith a # are global.
So variable #acdoc and #acspc are created at beginning of program  with:
  (or #acdoc (setq #acdoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq #acspc (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace #acdoc) (vla-get-ModelSpace #acdoc)))
;Added by GLAVCVS      Modified by ymg
(defun f3Dpol (plst /  sa i p element sa obj )
  (setq sa (vlax-make-safearray vlax-vbDouble (cons 0 (1- (* (length plst) 3)))))
  (setq i 0)
  (foreach p plst
    (foreach element p
      (vlax-safearray-put-element sa i (float element))
      (setq i (1+ i))
  (setq obj (vla-Add3DPoly #acspc sa))
  (vla-put-Color obj #Pathcol)
  (vla-put-lineweight obj #Pathlwt)
Here is mk_3dp:
;; mk_3dp    by Alan J Thompson                                               ;
;; Argument: lst, A list of points (2d or 3d)                                 ;
;; Create an 3dPolyline                                                       ;
;; Return: Polyline ename                                                     ;
(defun mk_3dp (lst / vtx)
  (if (and (> (length lst) 1))
        (entmakex
           (list '(0 . "POLYLINE")
                 '(10 0. 0. 0.)
                  (cons 8   #Pathlay)
                  (cons 62  #Pathcol)
                  (cons 370 #Pathlwt)
                 '(70 . 8)
        (foreach vtx lst
           (entmakex
              (list '(0 . "VERTEX")
                     (cons 10 vtx)
                    '(70 . 32)
        (cdr (assoc 330 (entget (entmakex '((0 . "SEQEND"))))))
And find below Benchmark result
_$ (benchmark '((mk_3dp lst) (f3dpol lst)))
Benchmarking ...............Elapsed milliseconds / relative speed for 4096 iteration(s):
    (MK_3DP LST).....1672 / 1.92 <fastest>
    (F3DPOL LST).....3218 / 1 <slowest>
_$
Edited by ymg3
20 hours ago, ymg3 said:
In your addition the F3dpol subroutine will be quite slow for path with long vertex due to the (apply append) actually 4 times slower than mk_3dp. If you insist on going visual lisp the following would be faster by a factor of 2.
  (setq i 0)
  (foreach p plst
    (foreach element p
      (setq i (1+ i))
Here is mk_3dp:
        (entmakex
                 '(10 0. 0. 0.)
                  (cons 8   #Pathlay)
                  (cons 62  #Pathcol)
                  (cons 370 #Pathlwt)
                 '(70 . 8)
        (foreach vtx lst
           (entmakex
                     (cons 10 vtx)
                    '(70 . 32)
_$
I use that code to create 3D polylines because it’s shorter, although I know that 'apply' slows it down a bit.
However, I didn’t think it would be as much as you say.
I was just about to reply with that.
But at the last moment, I managed to find a bit of time — and curiosity — to run a test.
And my results are somewhat different from what you describe.
I should mention that my test was carried out in AutoCAD 2002, using a list of 93 points previously stored in the variable 'plst'.
The code I used for this test is attached below.
(defun Original_f3Dpol (pts / tmp f3Dpol)
  (defun f3Dpol (pts / ep ll la e)
    (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace (vla-get-activedocument (vlax-get-acad-object))) (vla-get-modelSpace (vla-get-activedocument (vlax-get-acad-object))))
    (vla-put-Color e 1)
    (vla-put-Layer e "0")
    (vla-put-Lineweight e 0.4)
  (setq tmp (car (_vl-times)))
  (repeat 5000
    (f3Dpol plst)
    (entdel (entlast))
  (prompt "\nOriginal \'f3Dpol\' Elapsed time (5000 iterations): ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.")
(defun ymg_f3Dpol (plst / tmp f3Dpol)
    (setq i 0)
    (foreach p plst
      (foreach element p
        (setq i (1+ i))
    (setq obj (vla-Add3DPoly (vla-get-modelSpace (vla-get-activedocument (vlax-get-acad-object))) sa))
    (vla-put-Color obj 1)
    (vla-put-lineweight obj 0.4)
  (repeat 5000
    (Y3Dpol plst)
    (entdel (entlast))
  (prompt "\nModified @ymg3 \'f3Dpol\' Elapsed time (5000 iterations): ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.")
(defun ymg_mk_3dp (lst / tmp mk_3dp)
        (entmakex
                 '(10 0. 0. 0.)
                  (cons 8 "0")
                  (cons 62  1)
                  (cons 370 40)
                 '(70 . 8)
        (foreach vtx lst
           (entmakex
                     (cons 10 vtx)
                    '(70 . 32)
  (repeat 5000
    (mk_3dp plst)
    (entdel (entlast))
  (prompt "\n\'nmk_3dp\' Elapsed time (5000 iterations) : ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.")
The execution times for each version can be seen in the following image:
Your modification of 'f3DPol' actually seems to be even slower.
And 'mk_3dp' is only about 50% faster.
What's going on?
I don't know but I used "Benchmark.lsp | © 2005 Michael Puckett " to do the testing. Logically yours has to be slower because you run through the list so many more time either with apply (function append plus a mapcar for each element of the  list to to Float the coordinates.
Bear in mind it will only matter if the path found has a lot of coordinates.
ymg
We talk a lot about speed but does it matter, if it take seconds or a minute, a task I worked on could take up to 3 hours manually it takes 2 minutes now. I improved the speed 3 times by recoding. Yes if have thousands of lines go get a coffee. still faster than having a go manually.
I guess what I am saying are we talking seconds, minutes or hours ?
13 seconds for 5000, I would call that fantastic. If worried about time add a progress bar it's a Acet function.
The task above started at like 25 minutes to do, so 2 minutes as final version  is considered acceptable by me. Yes talking thousands of changes.
Edited by BIGAL
