request for capture A large number of coordinates points and them connect?
hello dear friends
:(i want lisp code the capture a large coordinates points and them connect by line, i know by scr do this, but in lisp how do this?
thanks a lot
There are vast number of possibilities... What type of array do you want after points are captured - connections by shortest distances from picked start point; by largest distances from picked start point; by nearest x coordinate from picked the smallest x coordinate start point; etc...
dear marko_riber
i want capture for example point1(5 8 10), point2(20 10 0) , ....., point1000( 10 20 25) and connect by line.
thanks
Do you already have ready list of points with correct array in a list... If so then this will do it...
(mapcar '(lambda ( a b ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b)))) ptlist (cdr ptlist))
if your possible, Bring a simple example that capture two coordinate point in the command line of user and connect them with command line.( my main goal i entered coordinates in command line, how do this?)
thanks
If possible please explain the this code and whether this code you put satisfied my request?
thanks
Here is quick explanation in concrete lisp routine...
(defun c:drawlines ( / p ptlist pp )
 (setq p (getpoint "\nPick or specify start point : "))
 (setq ptlist (cons p ptlist))
 (setq pp p)
 (while (setq pp (getpoint pp "\nPick or specify next point <Exit> : "))
   (setq ptlist (cons pp ptlist))
 (setq ptlist (reverse ptlist)) [color=red];;; Here ptlist has been generated ;;;[/color]
 [color=red];;; Here is the code for drawing lines from list of points (every 2 consecutive points are connected with line entity) ;;;[/color]
HTH, M.R.
dear marko, my problem is solved thanksssssss a lot
