andy_lee Posted September 17, 2014 Share Posted September 17, 2014 Hi guys At "Mode space" , I have some drawing. maybe is not the same as the size of the drawing frame . I need to arrange them neatly by drawing No. (1-SS706A-003). I hope can set Columns Can set Row spacing and columns spacing too! TEST1.dwg Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 17, 2014 Share Posted September 17, 2014 So you want to attach those drawings by their boundary sizes and column and row spacings... Do you know how many columns and rows are required or this data will be obtained from drawing names specifications... I suggest that you make lisp that will create scr file and that will execute that script, gathering *.dwg files opening each of them, check for boundary size, close it, attach it at right coordinates in main file from which script is running and repeat process for next *.dwg... Quote Link to comment Share on other sites More sharing options...
andy_lee Posted September 17, 2014 Author Share Posted September 17, 2014 So you want to attach those drawings by their boundary sizes and column and row spacings... Do you know how many columns and rows are required or this data will be obtained from drawing names specifications... I suggest that you make lisp that will create scr file and that will execute that script, gathering *.dwg files opening each of them, check for boundary size, close it, attach it at right coordinates in main file from which script is running and repeat process for next *.dwg... Hi marko. Thanks ! It seems very complicated . Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 18, 2014 Share Posted September 18, 2014 There is another post just last week trying to do same thing pick dwgs and insert in grid I know I posted. Will find pretty sure Tharwat answered. I posted a manual automatic solution. If th drawings are all the same size throw the list into excel and create row column using INSERT. Quote Link to comment Share on other sites More sharing options...
andy_lee Posted September 18, 2014 Author Share Posted September 18, 2014 There is another post just last week trying to do same thing pick dwgs and insert in grid I know I posted. Will find pretty sure Tharwat answered. I posted a manual automatic solution. Thanks BIGAL. your means is this ? http://www.cadtutor.net/forum/showthread.php?88694-insert-multiple-files-in-one-drawing If th drawings are all the same size throw the list into excel and create row column using INSERT. in the Model space , The drawings are not all the same size. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 18, 2014 Share Posted September 18, 2014 (edited) Problem with different size dwgs as just that you would have to look at every drawing first and make a bounding box then do row and spacing. Read my other comment about placing in the dwg text which is the name of the to be inserted dwg you can move this text and rerun a lisp which inserts a dwg at the text point nice thing is is if doesn't work undo or cancel move text a bit and do again. Edited September 20, 2014 by BIGAL same as other post Quote Link to comment Share on other sites More sharing options...
andy_lee Posted September 19, 2014 Author Share Posted September 19, 2014 I set Column= 5, column spacing=100, row spacing=100 Use Drawing number from left to right, from top to bottom of the order arrange here is end result. I done manuallyTEST2.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 20, 2014 Share Posted September 20, 2014 Sorry Marko_ribar just reread post and posted same as yourself I need to read a bit closer in future. Quote Link to comment Share on other sites More sharing options...
andy_lee Posted September 20, 2014 Author Share Posted September 20, 2014 Sorry Marko_ribar just reread post and posted same as yourself I need to read a bit closer in future. BIGAL, Marko Thank you for your reply. Honestly, I don't really understand .sorry for my poor english. Quote Link to comment Share on other sites More sharing options...
