Hi All.
i have recently buy Asus N550JK CM316H (16 gb Ram,4 GB Geforce dedicated Graphic,Core i7,2.50GHZ,1 TB Hard,Win 8.1 64bit).
After purchasing i had to intalled some Softwares but some application were not running well,then i Refresh my PC and install agin softwares now every thing is sported but some softwares (Civil 3D,3D Max) is running slow.
Kindly Help me is anay body has solution to make my applications running fast.
THX,
Dilshad
dil45: You should have started a new thread. This one is five years old.
Is hardware acceleration enabled in Civil?
In plain AutoCAD it is via the 3DCONFIG command. Not sure if the command is the same for Civil 3D.
in civil 3d acceleration is Enabled (Option>System>Graphic Performance) but have still problem.
Effects:
ACAD_LineSmoothing supported turned on
ACAD_PerPixelLighting supported turned on
ACAD_AdvancedMaterial supported turned on
ACAD_FullShadows supported turned on
ACAD_TextureCompression supported turned off
Do you have the latest drivers installed for your graphics card?
Did you disable the InfoCenter (also referred to as the CommCntr)?
Is this a standalone computer or are you working off a network?
Yes i have the Latest Graphic Card Driver installed and in using Standalone,
i did not disable infocentre
What do you consider to be slow performance?
What are you doing when the slow down occurs and what is happening on screen?
What sort of files are you working on? Filesize? Complexity?
Your computer specs appear to be more than good enough for running 3ds Max, so I'm not sure why you're having difficulty? Are you trying to work on huge models with millions of polygons?
Do you have a model on the video card? or a clock speed. Sometimes some cards have overclocked speeds and can become unstable. Most that come with a default overclock setting have a small switch close to the input power cables.
Also, as awful as this sounds, the computer itself could just be faulty in some way.
its normal work like Cross sections,Volume calculation,corridors.
During working feel sleepy because my cursor works slow Zoom in/Out Slecting items /copy/move Editing etc.
All other software's are working well.
You artfully avoided answering a handful of questions put to you so unless we start getting some answers it will be difficult if not impossible to provide further help.
And while you are at it, disable the InfoCenter too then get back to us.
Now i have to disable InfoCenter,Durrinf working the cursor performence is slow like sleepy.
Driver Detail.
Nvdia Geforce GTX 850m
Driver Version=340.52
Direct 3D Api Version=11.1
CUDA Core=640
Graphic Clock=901 MHz
Memory Data Rate=200 MHz
Memory Interface=128-bit
Memory Bandwiyh=32.03
total available graphic memory=12229 MB
Dedicated Video memory=4.96 mB DDR3
Shared system memory=8133 MB
video Bios Version=82.07.2A.00.02
Bus=PCI Express x16 Gen3
Device ID=10DE 1391 11CD1043
PArt Number=27030010
Please answer the questions Cad64 and Mike_Taylor asked previously too. Sloooooooooooowly, ever so slooooooooowly we'll get there.
Now i have solve the problen that was facing since few days.
I was due to Power Sawing/Balence.
