svrkjg Posted September 22, 2014 Posted September 22, 2014 Hello All, Thank you in advance. I can't seem to fix the error I keep getting no matter ho many times I do a "Attempt to Heal all Faces" procedure. I must be missing something here I can't see. Any advice or website link will be helpful. File is attached Ken Solidworks 2014 Standard Faulty Face Issue.zip Quote
JD Mather Posted September 22, 2014 Posted September 22, 2014 Worked fine for me on first run of Attempt to Heal All. Quote
svrkjg Posted September 22, 2014 Author Posted September 22, 2014 Hello JD, Thanks for your quick reply. I also was able to heal the face but when I opened up again I got the same error? Ken Quote
JD Mather Posted September 23, 2014 Posted September 23, 2014 I tried again, this time I saved and closed the file. When I re-opened and ran Import Diagnostics a second time - it was OK. Not sure what is happening on your machine. Quote
svrkjg Posted September 23, 2014 Author Posted September 23, 2014 Hi JD, Thanks again for your great support. There must be something wrong in my settings, when I created the Step file or during import/export operations. I'll have to see if tech support can help me, I might have a software glitch. Best Regards KenJG Quote
