RODH Posted September 30, 2014 Share Posted September 30, 2014 How do I match text for all the text on the sheet ? is there a command that does this,"matchprop" doesn't do this for text like it does for most all other things. To do this individually for each takes a lot of time..... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2014 Share Posted September 30, 2014 Can you be more specific about what you are trying to "match"? Quote Link to comment Share on other sites More sharing options...
Frei Posted September 30, 2014 Share Posted September 30, 2014 First you need to select some of them using the command 'selectsimilar', but first, send the command 'selectsimilarse' and make sure all options are selected. Once all the text is selected, press 'control + 1' and you should be able to match them all at once. Obs.: This only seems possible with Text objects and not MText (unless you explode them). Quote Link to comment Share on other sites More sharing options...
RODH Posted September 30, 2014 Author Share Posted September 30, 2014 Yes, hi thanks for reply. Specifically, I currently have existing text on the dwg which I am modifying to city blueprint style. The only way I do this is by edit text command to modify each text individually. I need to do it quicker if there is a command to do this like a match prop command , but don't know of one . Seems there must be a single command way to match text , rather than edittext, which requires highlighting the text and then going to the text editor finding the desired style, size and then is has to be done for each text I have to modify. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2014 Share Posted September 30, 2014 Did you try changing the font specified in the style? Quote Link to comment Share on other sites More sharing options...
RODH Posted September 30, 2014 Author Share Posted September 30, 2014 Yep, I can change the texts by changing the font and the size......... just gotta be a simpler way of doing like 200 of the same actions individually . Should be a way to make a group match text style, size, font change just like "matchprop" does for all else. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2014 Share Posted September 30, 2014 That's not what I'm asking and there is. Do you know what a text style is? It's a good way to change font for all the test assigned to that style. Now, if someone has gone and overwritten the properties of individual text in the editor it takes the control away from the style. If that is the case, find a LISP called STPMText and that will set the properties back so you can change the font in the style and have all the text assigned to that style change. Quote Link to comment Share on other sites More sharing options...
RODH Posted September 30, 2014 Author Share Posted September 30, 2014 Okay, thanks, how do i find a lisp? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2014 Share Posted September 30, 2014 I'll make it easy. http://forums.augi.com/showthread.php?53180-Change-color-of-existing-MTEXT-Objects Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 30, 2014 Share Posted September 30, 2014 That's not what I'm asking and there is. Do you know what a text style is? RODH, considering that your profile says you are running AutoCad LT 2013, running a LISP program is NOT an option, you might want to back up a bit and answer the above question. There is a default text style named Standard. Are you using this one, or has a custom text style been set up, or is going to be set up, that you need to change to. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2014 Share Posted September 30, 2014 RODH, considering that your profile says you are running AutoCad LT 2013, running a LISP program is NOT an option. Oops, I missed that, as usual. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 30, 2014 Share Posted September 30, 2014 Oops, I missed that, as usual.Hey, I have answered 3DS Max questions with AutoCad techniques and commands. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 30, 2014 Share Posted September 30, 2014 RODH, an easy way to determine the Text Style name, is to select a text object, then type properties. The Properties sheet will have a list of uh, um, properties, one of which is the text style. What is the text style name you are using? There has to be one. 2013 text does not function without at least one, the default, which is "Standard". Of course it can be overridden with all kinds of properties changes until it is unrecognizable, but that can be easily fixed, globally. Actually, if you are using the ribbon in 2013. once you select a text object, the Annotation tab will show the "current" text style of that text object. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 30, 2014 Share Posted September 30, 2014 Did the lunch bell go off? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 30, 2014 Share Posted September 30, 2014 I moved the thread to the AutoCAD LT Forum. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 1, 2014 Share Posted October 1, 2014 Another option is Filter select a text and edit the properties down to say Text style and maybe layer then just select entire dwg it will highlite those that match and you can use properties to change. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 1, 2014 Share Posted October 1, 2014 Since match properties is not working, I suspect that changing the properties won't work either. That is why I suggested that the properties were overwritten in the MText window which takes presidence over the properties of the entity. Quote Link to comment Share on other sites More sharing options...
eldon Posted October 1, 2014 Share Posted October 1, 2014 Post a drawing with some such text, and let the guessing cease Quote Link to comment Share on other sites More sharing options...
