gphil Posted October 1, 2014 Posted October 1, 2014 I am currenly building a split screen with 2 view ports. One is in planview and the other in in cross section orthogonal to plan view. Im trying to orient my text so that it can be viewed in both view ports. The Texts are changing axis with the viewports so all i see is a line in the cross section view. Thanks for the help! Quote
eldon Posted October 1, 2014 Posted October 1, 2014 If you rotate the text in 3D by 45 degrees, you will be able to see the text in both viewports. Quote
nestly Posted October 1, 2014 Posted October 1, 2014 There is no way that I know of to set up a text object so it's always displayed in a plan view regardless of the view angle. Depending on what the text is for, perhaps put in in Paperspace? Quote
