Damon :)
How do you use grips to modify an entity?
Share this post
Link to post
ReMark
This simple tutorial about using Grips in AutoCAD should get you started. For further information consult your AutoCAD Help file. Do you know how to do that?
https://www.andrew.cmu.edu/course/48-568/PDFs/AutoCAD2D/Chapter22.pdf
You might also benefit from the purchase of a good after-market AutoCAD book. Many such books can be found via Amazon. I'd recommend the series by George Omura published by Sybex.
Share this post
Link to post
rkmcswain
First, understand that is like asking "how do I drive a car?"
It is not easily put into a couple of paragraphs.
If you can take 12-1/2 minutes, this tutorial should help you a lot:
Share this post
Link to post
