Euga Posted October 4, 2014 Share Posted October 4, 2014 Hello! I have problem hatching in autocad 2014 to pdf or printing. In the model and layout hatch shows correctly, but when printing it doesn’t shows (wall and arrow hatch). It's not a matter of scale because it's a solid grey hatch. I've made 2 photos of printed file. In the morning everything was ok (picture 1), but later it somehow messed up (picture 2). On the colleagues computer everything prints ok. We are both using the same plotter. P.S. „Shade plot” is set „As displayed”. And Layer Manager is chosen printable. Has anyone had this problem before? Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
BMXerScott Posted October 6, 2014 Share Posted October 6, 2014 Are you both using the same CTB file? Quote Link to comment Share on other sites More sharing options...
Euga Posted October 7, 2014 Author Share Posted October 7, 2014 Yes, we both using the same CTB file. Is there any settings to avoid these problem? Heeeelp Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted October 7, 2014 Share Posted October 7, 2014 I suspect the CTB file may have become corrupt on the OP's computer or was replaced with a different CTB when they opened a different file. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 7, 2014 Share Posted October 7, 2014 I highly doubt it is a .ctb issue. Those objects are different colors and I'm betting that the leader does not have a different color for the arrowhead. It's more likely some setting having to do with solids. Quote Link to comment Share on other sites More sharing options...
BMXerScott Posted October 7, 2014 Share Posted October 7, 2014 Does the OP maybe have his Hatch Transparency set so low that it's not printing? Of course that doesn't explain the arrowhead disappearing... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 7, 2014 Share Posted October 7, 2014 Be nice to have the .DWG file. At least a screen shot of the plot settings. Is "Hide Paperspace Objects" checked? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 7, 2014 Share Posted October 7, 2014 It's a local issue as the OPs colleague can print it fine. A file is not going to help but the settings will. If it were a paper space object issue, why would only part of a leader plot? Quote Link to comment Share on other sites More sharing options...
Euga Posted October 8, 2014 Author Share Posted October 8, 2014 Thank you!!! I set ticks to plot transparency and plot with plot styles ans everything printed fine How exactly are these things connected? How to understand whether its needed to turn the settings on and off in future projects? Quote Link to comment Share on other sites More sharing options...
