I am currently working in AutoCAD 2000, and don't know how to format my text so that my fractions automatically stack? I attempted to use the help menu where it says use #, / , or ^ between numbers but no cigar... Help! :?
Abit lengthy in detail, but worth
Run MTEXT a enter the variable value as fraction in the text editor
MTEXT creates a default A/B. Select the fraction, right-click and choose Stack Properties to display the fraction dialog box. In the dialog box, set the style to either diagonal or horizontal & tolerance settings. Do check if this is the right default for you.
