Cut extrude on ciruclar surfaces
Hi
Just a quick question concerning cut extrude on circular surfaces:
Is the cut extrude I have done in the attached file a "best practice" way of doing it (the sketch is way past the circumference of the circle, so I am trying to ask if this matters, or if there is some "prettier" way of doing the sketch).
Stepped shaft.SLDPRT
You do not need the 4mm dimensions - simply add Tangent relations between the sides and the circle.
(Or in this case you could also use Coincident since you already have a construction line constrained to the circle.)
I would have used a center point rectangle instead.
Edited by JD Mather
Thank you very much, I will try this!
