YAZ
Autocad Script to plot multiple tabs in one file
YAZ
HI, I HAVE A SIMPLE SCRIPT FILE THAT PRINTS SPECIFIC TABS INSIDE A CAD FILE, IS IT POSSIBLE TO CHANGE THIS TO MAKE IT PLOT MULTIPLE TABS "LAYOUTS" IN THE SAME FILE, BASICALLY WILL BECOME EQUIVALENT TO A PUBLISH "BATCH PLOT" COMMAND.
-PLOT
Y
PV2.00
DWG TO PDF.PC3
ARCH full bleed E1 (30.00 x 42.00 Inches)
I
L
N
L
F
Y
SoCore_2014.ctb
Y
Y
Y
N
N
Y
Y
THNX
Share this post
Link to post
RobDraw
The obvious answer would be to use publish and named page set-ups. (Or is it sets-up?)
Share this post
Link to post
BIGAL
Here is a quick answer, we have 2 versions plot all or this one plot range.
;Plots layouts by range
; By Alan H Feb 2014
(defun AH:pltlays ( / lay numlay numend)
(setq numlay (getint "\nEnter Start tab number"))
(setq numend (getint "\nEnter last tab number"))
(setq len (+ (- numend numlay) 1))
(repeat len
(vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= numlay (vla-get-taborder lay))
 (setvar "ctab" (vla-get-name lay))
) ; if
(princ (getvar "ctab"))
) ; for
(setq lay nil)
(COMMAND "-PLOT" "Y" "" "COLOR-PRNA3" "A3" "m"    "LANDSCAPE"	   "N"   "W"  "-6,-6"    "807,560"	"1=2"  "C"
       "y"	  "Designlasercolor.ctb" "Y"	"N" "N" "N" "N" "N" "y"      )
(setq numlay (+ numlay 1))
) ; end repeat
) ; defun
(AH:pltlays)
Share this post
Link to post
BlackBox
FWIW -
AUTOPUBLISH was implemented in 2009, and can plot to multi-document PDF, and DWF in a relative (to DWFPREFIX), or specified (always the same, i.e., Documents, etc.) path of your choosing.
Configured to use a named page setup, I simply SAVE* a document, and resultant PDF is produced automagically. :thumbsup:
Cheers
Share this post
Link to post
YAZ
Autopublish does it beautifully, thank you very much
Share this post
Link to post
BlackBox
You're welcome, YAZ; I'm happy to help.
FWIW - I also use a custom app to make AUTOPUBLISH only produce electronic documents for exhibits and sheets, and not for DREF/XREF-only drawings... Should that be of interest, see the Exchange link in my signature.
Cheers
Share this post
Link to post
