Is there a code to find out current cad version or identification code ?
I'm pretty sure that question has been asked and answered here (possibly this year too). Try a search.
Depends on what you're attempting to identify; I've also used:
(vl-load-com)
(if vlax-user-product-key                                               ; If 2013+
 (vlax-user-product-key)                                               ; Use new function
 (vlax-product-key)                                                    ; Use legacy function
... And another one (read-only for LISP, write-enabled for .NET API):
(vl-load-com)
(vla-get-caption (vlax-get-acad-object))
Some more examples
;vercheck.lsp  version check for *aecc objects
(defun ah:vercheck ( / vrsn appstr)
(vl-load-com)
(if ((lambda (vrsn)
       (cond
        ((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09
        ((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10
        ((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11
        ((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ?
        ((vl-string-search "R19.0" vrsn) (setq appstr "10.0")) ;13
        ((vl-string-search "R19.1" vrsn)(setq appstr "11.0"));;2014
        ((vl-string-search "R20.0" vrsn)(setq appstr "12.0"));;2015
        ((alert "This version of C3D not supported!"))
      (vlax-product-key)
     )                         ; end if condition progn is true
       (cond (*AeccDoc*)
         ((setq *AeccDoc*
           (vlax-get
             (cond (*AeccApp*)
               ((setq *AeccApp*
                 (vla-getinterfaceobject
                    (cond (*Acad*)
                    ((setq *Acad* (vlax-get-acad-object)))
                    (strcat "AeccXUiLand.AeccApplication." appstr)
             'ActiveDocument
       ) ; end main cond
     ) ; end progn
) ; end if vsrn
