Frei Posted October 20, 2014 Posted October 20, 2014 (edited) Hello everyone, recently I edited a simple routine to automatically generate .pdf files in both monochrome and coloured plot styles; currently I've been trying to create a routine for .plt files - the problem: the routine is running fine with the window selection, paper size center, etc. until it asks me the following: "Plot with lineweights? [Y/N]" - my answer is "Y" as I do want to keep the lineweights. "Scale lineweights with plot scale? [Y/N]" - not sure, I had it set to "Y". This is my routine: (defun c:plttest (/ fl) (setq fl (strcat (getvar "dwgprefix") (getvar "dwgname"))) (setq fl (strcat (vl-string-right-trim ".dwg" fl) "-" (getvar "ctab") ".pdf")) (if (findfile fl) (command "-plot" "Y" "" "HP Officejet Pro 8600 (Rede)" "A4" "I" "L" "N" "W" pause pause "F" "C" "Y" "Monochrome.ctb" [color="red"][b]"Y"[/b][/color] "" [color="red"][b]"Y"[/b][/color] "" "Y" "" "Y" "") (command "-plot" "Y" "" "HP Officejet Pro 8600 (Rede)" "A4" "I" "L" "N" "W" pause pause "F" "C" "Y" "Monochrome.ctb" [color="red"][b]"Y"[/b][/color] "" [color="red"][b]"Y"[/b][/color] "" "Y" "" "Y" "") );if (princ) ) ---------------------------------------------------------- AutoCADs outputs (the original A0 format I made): ---------------------------------------------------------- Detailed plot configuration? [Yes/No] : y Enter a layout name or [?] : Enter an output device name or [?] : DesignJet 650C C2859B.pc3 Enter paper size or [?] : ISO A0 (841.00 x 1189.00 MM) Enter paper units [inches/Millimeters] : I Enter drawing orientation [Portrait/Landscape] : L Plot upside down? [Yes/No] : N Enter plot area [Display/Extents/Layout/View/Window] : W Enter lower left corner of window : Enter upper right corner of window : Enter plot scale (Plotted Inches=Drawing Units) or [Fit] : F Enter plot offset (x,y) or : C Plot with plot styles? [Yes/No] : Y Enter plot style table name or [?] (enter . for none) : monochrome.ctb Plot with lineweights? [Yes/No] : Y Scale lineweights with plot scale? [Yes/No] : Y Plot paper space first? [Yes/No] : Y Hide paperspace objects? [Yes/No] : Y Write the plot to a file [Yes/No] : Y Save changes to page setup [Yes/No]? Y Proceed with plot [Yes/No] : Y Effective plotting area: 815.83 wide by 1153.41 high Plotting viewport 1. Effective plotting area: 796.29 wide by 953.52 high Plotting viewport 2. -------------------------------------- It looks right, but when I test the .plt it looks just rubbish, like a glitched print. I also tried answering "N" to both variables but the result was a very, very thin lineweight rather than the default 0.2500mm. Is there any workaround for this problem? Edited October 23, 2014 by Frei Quote
BIGAL Posted October 21, 2014 Posted October 21, 2014 Have you checked the monochrome line weights using the ctb will override your line settings my settings no probs (COMMAND "-PLOT" "Y" "" "dwg to Pdf" "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "Designlasercolour.ctb" "Y" "n" "n" "n" pdfName "N" "y" ) ) Quote
SLW210 Posted October 21, 2014 Posted October 21, 2014 Please read the Code Posting Guidelines and edit your posts to include the Code in Code Tags. Quote
