VBA to set printer
hi all
i have marco to issue many drawing automatically, and now i want to set up printer for them to print faster. so please help me to write VBA to setup printer for autocad drawing as following:
1. change to Layout and add viewport to frame of drawing (the frame shall be scaled in each drawing)
2. Printer/Plotter: default printer
3. paper size: A3
4. plot area: window (get all drawing in layout)
5.Plot offset: center the plot
6.Scale: fit to paper
7.Plot Style table: Monochrome.
thanks
It is an example of the method of how to do you would need to rewrite in VBA, do you know how to program VBA ?
hi. i just know VBA, not LISP. so would you please help me to program in VBA. thanks.
ex: draw Rectang in Model, then move to Layout and set printer as following setting:
1. in layout, add viewport to Rectang
2. Printer/Plotter: default printer of PC
3. paper size: A3
You need to understand within VBA some basic principles I am no expert but know enough to do basic programming. Have you checked the developers Help from within Autocad?
Vlisp version detailed there will be documentation for all these steps as VBA
open the autocad document (vla-get-activedocument (vlax-get-acad-object))
get the layouts as a group from the document(vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
loop through the layouts one at a time (vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
this returns the layout number (vla-get-taborder lay)
Open up the current layout ctab by retrieving the layoutname (setvar "ctab" (vla-get-name lay))
The (command "Plot".... could be done by invoking a plot script VBA thisdrawing.plot http://forums.autodesk.com/t5/visual-basic-customization/automated-print-from-vba-using-a-saved-page-setup/m-p/2250520
A quick google and this was found here at Cadtutor solves 1 problem Cadtutor is not a write code for me service if you want that then you either pay someone or wait for possible help.
Sub FindLayouts()
   Dim oLay As AcadLayout
       For Each oLay In ThisDrawing.Layouts
           MsgBox oLay.Name
       Next
End Sub
thanks BIGAL
i completed with my program. below is my program
Sub Example_PlotType()
   Dim ACADLayout As ACADLayout
   Dim originalValue As Integer
   Dim Print1 As String
   Dim Paper1 As String
   Set ACADLayout = ThisDrawing.ActiveLayout
   Print1 = "HP LaserJet 5200 Series PCL 5" ' name of my printer
   Paper1 = "A3" 'type of paper size
   ACADLayout.PlotType = acExtents
   ACADLayout.CenterPlot = True
   ThisDrawing.ActiveLayout.StyleSheet = "monochrome.ctb"
   ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
   ThisDrawing.ActiveLayout.ConfigName = Print1
   ThisDrawing.ActiveLayout.CanonicalMediaName = Paper1
End Sub
Edited by nguyendan81985
FWIW -
Methinks it a far simpler implementation to import a named page setup, and apply that to Layouts.
If/when you decide to step up into .NET API, this old post may be of use.
Cheers
