abishop Posted October 24, 2014 Posted October 24, 2014 Does Inventor allow you to make an assy drawing showing the parts blown apart? Kind of like showing how the assy goes together and show ballons? Thanks Andy B Quote
JD Mather Posted October 24, 2014 Posted October 24, 2014 Yes. See the tutorial on presentation files (*.ipn) exploded assembly views. Quote
abishop Posted October 24, 2014 Author Posted October 24, 2014 can you point me a little closer? I am not familiar with the tutorial files and there seems to be a lot of them. Thanks Quote
JD Mather Posted October 28, 2014 Posted October 28, 2014 I recommend doing all of them http://help.autodesk.com/view/INVNTOR/2014/ENU/ especially if (snip)..... Quote
lrm Posted October 30, 2014 Posted October 30, 2014 Expand the list of tutorials under Presentations (about half way down the list of tutorials). You can get a feel for the process in Tweak the Retaining Ring and then Place an Exploded View. When I make a exploded view with Inventor I rotate the view to a desired orientation I think will be the most descriptive and then remove some of the assembly constraints. I then just drag the parts around on the screen. Quote
