Hi guys!!
How are you?
I need help to control the text size of my code.
Anybody Can help me out help?
(defun C:ld (/ osm pt prf suf)
 (vl-load-com)
 (defun *error* (msg)
   (if	osm
     (progn (setvar "osmode" osm) (setvar "cmdecho" 1))
   (or	(wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **"))
 (if (not num)
   (setq num 1)
 (setq osm (getvar "osmode"))
 (setvar "osmode" 0)
 (setvar "cmdecho" 0)
 (if (and (/= (setq prf (getstring t "\n Type prefix : ")) "")
   (/= (setq suf (getstring t "\n Type suffix : ")) "")
   (setq num (cond ((getint (strcat "\n Enter an initial number < "
				    (itoa num)
		   (t num)
   (while
     (setq
pt (getpoint
     "\nSpecify leader start point: (or hit ENTER to Exit) :"
      (command	"._leader" "_non"
	pt
	pause
	(strcat prf " " (itoa num) " " suf)
      (setq num (1+ num))
(princ "\nStart command with LD")
Regards
What about variable .
DIMTXT
