Ricardo Posted February 4, 2007 Posted February 4, 2007 How can I open a .plt file? I can't find it anywhere on CAD. Quote
Wozza Posted February 5, 2007 Posted February 5, 2007 Ricardo, This has just been answered in the Autocvad General area. Check there for an answer. Quote
rkmcswain Posted February 5, 2007 Posted February 5, 2007 How can I open a .plt file? I can't find it anywhere on CAD. Open it to do what, view it? See: http://cadpanacea.com/node/28 Quote
f700es Posted February 5, 2007 Posted February 5, 2007 How can I open a .plt file? I can't find it anywhere on CAD. If you have the Express Tools installed type..."plt2dwg". It seems that only certain ones can be converted but maybe worth a shot. Good luck Quote
Cad64 Posted February 5, 2007 Posted February 5, 2007 PLT2DWG only translates Plot files that are in HPGL format. Quote
f700es Posted February 5, 2007 Posted February 5, 2007 PLT2DWG only translates Plot files that are in HPGL format. Hence why I said only certain ones. His might be, worth a shot Quote
Cad64 Posted February 5, 2007 Posted February 5, 2007 I'm not trying to step on toes here, I was merely expanding upon what you had posted. You didn't mention why it only translates certain ones, so I thought it was worth mentioning. I apologize if you took offense. By all means, give it a try, but if it doesn't work, it's because it's not HPGL format. Quote
rkmcswain Posted February 5, 2007 Posted February 5, 2007 I'm not trying to step on toes here, I was merely expanding upon what you had posted. You didn't mention why it only translates certain ones, so I thought it was worth mentioning. I apologize if you took offense. By all means, give it a try, but if it doesn't work, it's because it's not HPGL format. Just to add, I have not seen an HPGL plot file in a l o n g time... That ET has little value these days. Quote
Dommy2Hotty Posted February 5, 2007 Posted February 5, 2007 We use Oce Repro Desk to open the .plt files before we send them to the printing company to make sure they're correct. This is VIEWING ONLY! If there are changes that need to be made, the .plt file needs to be re-made thru AutoCAD. Quote
f700es Posted February 5, 2007 Posted February 5, 2007 I'm not trying to step on toes here, I was merely expanding upon what you had posted. You didn't mention why it only translates certain ones, so I thought it was worth mentioning. I apologize if you took offense. By all means, give it a try, but if it doesn't work, it's because it's not HPGL format. Not at all bro I had forgotten exactly why but I knew there was a reason it only works on certain ones. Thanks for the details on it though. No offense at all We all (well most of us) gain from the input of others, the more the better. Sean Quote
Ricardo Posted February 5, 2007 Author Posted February 5, 2007 Open it to do what, view it?See: http://rkmcswain.blogspot.com/2006/03/update-plt-file-viewers.html I'm using AutoCAD 2000 and a friend sent me a few shop drawings and permit drawings on .plt format via email. I saved it on to the AutoCAD folder but when I go to open it, it isn't there and I can't find it anywhere else. All I want to do is view them, but they don't show up. Any idea where they are? Quote
rkmcswain Posted February 6, 2007 Posted February 6, 2007 I'm using AutoCAD 2000 and a friend sent me a few shop drawings and permit drawings on .plt format via email. I saved it on to the AutoCAD folder but when I go to open it, it isn't there and I can't find it anywhere else. All I want to do is view them, but they don't show up. Any idea where they are? Don't show up where? Are you trying to "open" them from inside AutoCAD? You can't, you will have to use one of the programs on that list (or something similar). AutoCAD does not "read" or "import" PLT files (with the exception of the ET that only reads HPGL files) Quote
bjonz Posted August 21, 2012 Posted August 21, 2012 Rosetta PreVIEW can open all PLT's (and it's a free download) http://rosetta-preview.software.informer.com/ Quote
